Old 05-08-2020, 12:05 PM   #241
Chrisguga   Chrisguga is offline
Threads on the side are fine. I'm just curious how much rubber or how thick that tire is in the center. I'll probably go ahead and order a rear tire anyway just to have on hand ready to go.
Yeah, I guess in my mind I’ll just ride it until I see cords. lol
I don’t do high performance riding anyway.
But, I will go ahead and order a new one too. I guess I need to start researching tires.
2019 Venom X22R
K&N pod air filter, removed cat, 105 main jet, 36 tooth rear sprocket, RK racing 428 chain, oil cooler, NGK plug, bar risers, aftermarket mirrors, Grab On grip covers, phone mount/charger, Pro Grip tank protector, Chase Harper tank, tail, and saddle bags.
Old 05-08-2020, 01:23 PM   #242
Your only choice in a 140/60-17 tire is the Shinko 006 Podium Radial. You will have to go a little wider or narrower to find any other brand besides the stock Chinese tire.
2004 Honda ST 1300
Old 05-08-2020, 02:15 PM   #243
Gotcha, I’ll definitely go wider then. It’ll look better being slightly wider and the tiny bit of extra height will also give us an even taller gear ratio.
Speaking of... we could gear the bike taller by getting a taller sidewall on the rear tire. I don’t know if that’s something people regularly do on motorcycles.
2019 Venom X22R
Old 05-09-2020, 04:45 AM   #244
franque   franque is offline
You can do that, but it's also possible to change the handling quite a bit, too, as it'll effectively decrease trail by effectively decreasing steering rake. It'll make for twitchier handling if you change it too radically.
Old 05-09-2020, 09:44 AM   #245
Ina Ditch   Ina Ditch is offline
Ina Ditch's Avatar
I have a very old Harbor Freight Mig welder that still works great. Too bad they don't sell that model anymore. It was made in Italy and not China. lol
I think this header pipe would work but would still have to add length to the pipe. I haven't given up hope on finding the right one but when i do i'll be sure to post it.
https://www.aliexpress.com/item/4000...1-c255ea19b9d4
https://primeweld.com/ I have a shop full of welders, I bought these out of curiosity figuring if they were decent that I would give them to my son in law and grandsons. I have been happy with them, as a matter of fact I played with the yes welder mig yesterday for awhile. I know first hand that PrimeWeld has excellent customer service and YesWelder refunded my money and let me keep some mig nozzles to compensate for slow delivery which was not their fault so I suspect their reputation for good customer service is earned as well. I have 2 of the PrimeWeld multi-process machines and the YesWelder 165 dc arc/tig and 205ds mig, they are in the HF price range and very good for the price. OK, I hijacked the thread long enough, if you have more interest PM me and I will answer questions. Chris, I live near you and maybe able to help you out with your exhaust cat.
Old 05-09-2020, 10:26 AM   #246
Ina Ditch's Avatar
OOPPSS, I see your exhaust is done, didn't read far enough into the thread before shooting my mouth off. my mamma warned me about that.
Old 05-09-2020, 10:08 PM   #247
Ina Ditch, I appreciate your offer, but I did get the cat out and the amateur welds are holding up so far.
Jerry, I meant to mention that while it may be placebo, the bike felt smoother than ever after adding those balancing beads. I was cruising along at around 65, not even thinking about the beads, and just thinking how good the bike felt. I felt like I was going slower than I really was and then remembered I added those beads. So, they might be worth a shot. I figured for $18, I’d go for it.
The key to getting them in is to fill the plastic tube halfway and then blow them in. But, the condensation from your breath will start clogging the tube so you have to wait 15-20 seconds between applications to get them to go in smoothly.
2019 Venom X22R
Old 05-09-2020, 11:41 PM   #248
Ina Ditch's Avatar
not a problem, glad you got it done. I'm amateur to so you probably did as well as I could have I just didn't read far enough to realize you had a machine. I am enjoying this thread!!!
Old 05-12-2020, 07:20 AM   #249
Who doesn’t like pictures?!? I cleaned it up a little and tried to take a few decent ones.
File Type: jpg FF817994-9EB8-40FB-9F1F-F15F7025942D.jpg (19.6 KB, 219 views)
File Type: jpg 7AD3F079-029A-47AB-A5B5-BDF244B4AD92.jpg (19.9 KB, 220 views)
File Type: jpg 9844A25A-ADA9-4140-9306-8AC0350F9476.jpg (20.3 KB, 214 views)
2019 Venom X22R
Old 05-12-2020, 07:31 AM   #250
Looks almost as pretty as mine. Looks great!
2004 Honda ST 1300
