#241 | |
Four strokes on the other hand, develop far more friction, heat and have "hot spots" because of far more moving parts that need to wear in and surfaces that need mate with each other like cam lobes, lifters, rockers, cam bearings, etc...so I've always broke in my 4 strokes as recommended by the manufacturer. That said, it's like oil threads, everyone should do what they think is best for their own bikes.
#242 |
Yes, the big difference between then and now is that pretty much everything was 2 stroke back then. Good catch!!
#243 |
I remember a few years back we had a member here who bought a brand new Qlink from my dealer in Sac, ran the thing hard and wide open out of the box and a week later, I saw it in my dealers shop with a grenaged motor on the bench because the cam bearing seized at redline. It was a mess. The guy actually blew it up twice and my dealer said "no more" on the warranty repairs.
#244 |
The two four stroke thing is very true ,but we are still doing it with brand new mx bikes today ,which have very complicated and expensive valvetrains and it's actually very very rare that we have an engine failure that's not related to a lazy or uninformed owner not taking care of the valve maintainance .The valve train only runs at half engine speed anyway .The two smokers also revved much much higher than the four strokes .
#245 |
I'm sorry but I'm not gonna take a bike out of a box that is known to have TIGHT valves, crappy oil, and a LEAN air fuel mix and run it like that. Ski didn't know any better amd I'm sure his bike is ok. Wonder if Spud Rider broke in his 50 THOUSAND MILE CG like a mad man. Something tells me he didn't
#246 |
He did change the oil before he cranked it. I've been helping him with the assembly. I spoke with him this morning. He's got the idle down some but was still idling fast. He had the idle screw just about all the way out and was still idling fast. I Had him check and adjust the throttle cable and check for cable binding. I think that may have been the problem because he couldn't get it to start more than likely because the idle is set to low now. He had to run out for a while today and he will work on it later today. One thing I have to say about Ski is the reason it took a while to put together is because he took his time to put it together to make sure everything was correct. We have to remember he and Enforcer were the 1st to assemble one of these and had no instruction or threads on here to go by. He has done a great job at putting this bike together. Okay enough of me.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 03-10-2017 at 03:02 PM. |
#247 | |
#248 |
Break-in threads and oil threads are like hemorrhoids! LOL! They always come back to haunt....... ;-)
#249 | |
#251 |
That looks great! Love the red!
#252 |
Glad to help. And the Hard break in method worked lol.
#253 |
Looks great and sounds great! That remote start is just pretty nifty. I like
Hawk 250 Mikuni carb 115 main. De-catted pipe. Air box mod. 15/42 sprockets. Digital instrument cluster, FMF end cap on muffler, handlebar toolbag, Custom foot pegs |
#254 |
Awesome...and now you can ride it a little, and then change the oil and check the valve adjustment again in a few hundred miles. When it warms up a little anyways! These are all good lessons you'll never forget!
#255 | |
