#226 | |
Brian Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com "Imagination is more important that knowledge" Albert Einstein |
#227 |
Looks like ya had a good time.
2016 Brozz |
#228 |
Is the sprocket sizes the same on the Brozz and Shark?
#229 |
Somewhere there's a thread with comparisons of vital info, I'll see if I can dig it up....
![]() Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf...... |
#230 |
I've looked, but havnt found anything about stock sprocket tooth on both. Ill count mine when I get a chance. I'm cruising at 55 about 6000rpm " i think"....Not sure if this is the ideal gearing for back roads.
#231 | |
Ive got 700 miles on mine now
#232 |
Just counted, the rear sprocket on my 2016 Brozz is a 47 tooth
#233 |
Pretty sure you miscounted I counted 46
2016 Brozz |
#234 |
Welp, I ordered me that fancy exhaust system this afternoon. I procrastinated for a while as I'm fairly content with how my Brozz runs. But the weight loss alone was pretty much enough to make the switch.
Looking forward to its arrival.
#235 | |
#236 |
Mine is off exactly 5mph by my gps.
#237 |
Exhaust came in today. I have it installed and I am very glad that I bit the bullet and ordered it. So much so, that I would encourage anyone who is on the fence to do so.
Mine did NOT mount to the exact same mounting locations as the factory. The muffler wanted to be mounted further forward than stock bu the Brozz (and maybe others) happen to have a perfectly located hole there to use. Mine was a little uncomfortably close to the airbox, so I used a hammer and "smashed" the pipe a little to gain a few mm's clearance. I have not had it on the road but around the property it is defiantly louder, (not obnoxious, just sounds deeper, better) and does seem to allow a significant amount of air flow. Best mod I've done thus far~
#238 | |
http://stores.ebay.com/RCH-ACCESSORI...sub=9070513010 I did have to bend it a bit and I used a rubber hammer for that. I also used header wrap. ![]()
#239 |
That's the one, in Titanium color. And Brian was right about the Brozz having s perfectly placed hole for mounting the muffler. I just stacked a shitload of 3/8" SS flat washers to space it out correctly, and used the long bolt that's included with the exhaust
#240 |
You were right, and we were both foolish for even counting. It was right there staring us in the face all along Lmfao!
