07-04-2017, 06:49 PM | #226 |
That doesn't bother me much. If worse comes to worse, I can open up the hole on the back where the switch is and just solder leads to the board mounted switch and run them to the remote switch.
Stuff did happen today. First headache was that the OD of new speedo is 88.5mm. The ID of the hole was 85.5mm. Started opening the hole with a Dremel and stone. After about ten minutes of this, and knocking off a whole .25mm, I glanced up and saw my air compressor. And then a light went on and I said to myself, "Self, are you an idiot, or what? There is a drawer in the big tool box with air tools. I bet if you look, there is a die grinder with a real stone in there. Jackass." So, five minutes later, the speedo dropped in place. I also figured out that the big rubber ring on the Ural speedo wasn't for looks, but to lift the speedo high enough to clear a crossbar running through the nacelle. So, I needed to do some OE&F on that, too. Then I called it a day. CX500 for the next week or so. Will see if I can still ride it.
07-04-2017, 09:49 PM | #227 |
That's where the dremmel will come in for the back of the case to extract the button. I used to scoff at the dremmel tool till my uncle raved so much about it that I broke down many years ago and got a set. I just used it to cut out a damaged bearing race on a rotary torso machine the other day, mighty handy indeed.
Looking good!
07-05-2017, 09:33 PM | #228 |
Nothing done today. Long, hard, and hot day at work.
07-06-2017, 10:16 PM | #229 |
Did some wiring today. Powers up; hi beam and neutral lights work. No luck wrapping the tach signal wire around the plug wire. Supposed to be cooler tomorrow and it's Friday. Maybe wrap things up late tomorrow night.
07-06-2017, 10:40 PM | #230 |
On my 250cc the tacho wire connected to the blue and white stripe wire between the mag stator and the cdi
I know Yours is probably different.
07-06-2017, 11:22 PM | #231 |
Probably, it's a Ducati Hall Effect system. But, it bears looking into.
07-07-2017, 11:28 AM | #232 |
I found a Google reference to it on the CURD forum, but couldn't find the actual thread. Perhaps you'd care to sign up there so you can search the topic. BTW, it was a link from Soviet Steeds.
07-07-2017, 12:33 PM | #233 |
https://item.taobao.com/item.htm?id=536139476392 had good tips.
Basics in that url = Rpm signal can gotten from multiple locations. Find the least inference 1 by ur self (or shielded that wire) 1. the electronic rpm gauge line (some model had this, the signal is best) 2. IGN coil in (If don't had 1 recommend connects to here) 3. CDI's out 4. CDI's IN 5. Trigger's out 6. ECU's out...
07-07-2017, 05:26 PM | #234 |
Thanks guys.
I registered for the CURD forum, Weld. Thank Ja for wikipedia if one isn't Canadian. Needed to know the name of the bridge to PEI to get registered and I didn't even remember one being there the last time I was to Cape Breton. (my kids were 10 and 6, now 38 and 34) HB-1, 3, 4, 5, and 6 don't exist on the Ural, so #2 it is.
07-07-2017, 10:41 PM | #235 |
Success.
There was a blue wire and a white wire at the coil, so I had 50% chance of getting it right the first time. I tried the blue one and found that the white one was the one I needed. This was still easier than getting the right turn signal hooked up. Ural seems to have their own color codes that change between harnesses, which slows things down a bit. Still haven't dealt with the speedo pickup but that should be a piece of cake(famous last words)
Cheesy ______________________________________ 07 Hi Bird Enduro-Flown the Coop 07 Ural Gear Up 79 Honda CX500 77 VeloSolex 4600 V3 73 VeloSolex 3800 I'm making this up as I go.-Indiana Jones Telling me something 'is for my own good', is a fast way to a fat lip.-Me I don't even care about my own problems, why should I care about yours?-Quote on one of my favorite t-shirts Last edited by cheesy; 07-07-2017 at 10:42 PM. Reason: brain faster than fingers |
07-08-2017, 12:49 AM | #236 |
My solution
A little aluminum and a bench vice worked nicely
07-08-2017, 09:17 AM | #237 | |
07-08-2017, 05:19 PM | #238 | |
The wire color thing was aggravating. Orange at right front signal, light blue at the rear and neither of those colors were in the headlight bucket. Used my Beta MM with the sooper dooper pointy probes and found the white/red wire from the turn signal switch that was the one I needed. On the other side of the plug, the wire was gray/green. Not a lot of room in the rats nest to work, plus I gotta worry missing the wire with the probe and impaling my finger. Gave up on finding a solenoid to press the reset button. Resorted to cutting part of the back off the speedo to access the switch and soldered leads and the remote button to it. It works. Also added a plug between the remote button and the speedo so I don't have to swear at myself when I put the speedo back in. Just waiting for the JB Weld to set.
07-08-2017, 11:36 PM | #239 |
Ya know....I haven't had to do a darn thing to my rig since I got it all put together.
07-09-2017, 06:29 AM | #240 | |
With some luck, I should wrap this up today.
