03-08-2011, 10:35 PM | #226 |
Here are some more photographs of my completed battery relocation.
Here's the obligatory, 6 o'clock view showing the missing battery box. The Shorai battery cranks the engine very well, and I love having the bike 9 pounds lighter! Spud
03-10-2011, 10:59 PM | #227 |
The high temperature surpassed 50 degrees Fahrenheit today, so I went for a ride, and took some photographs. Here is the condition of my Maxxis, Maxx Cross, IT rear tire after riding 300 miles on pavement.
I have discovered the Maxx Cross, IT rear tire grips well in the mud. The Maxxis IT tire also cleans itself very well. My CST, Surge I, front tire grips well in all conditions, and is showing very little wear after 600 miles on pavement. After riding 100 miles today, I was very happy to clean a few bugs off my helmet visor! You might fool men, but you can’t fool the bugs; spring is just around the corner! I’m also pleased to report my Shorai battery cranks the XR650L engine hard, and starts the bike easily. I am very pleased with the results from my Shorai battery relocation. Spud
03-11-2011, 12:01 AM | #228 |
Spud, for all the beautiful pictures we members share here I don't think anyone has as beautiful a riding area as you do. You are blessed .
The Maxxis looks like a good tire, good grip on and off road, and it seems to be holding up well. I bet that motor can tear a tire to bits in no time 8O . You have good restraint! God knows I can't stay out of the throttle on the 650's. I already plan to be buying Rand new tires... :P
Happy to serve. |
03-11-2011, 12:13 AM | #229 | ||
03-18-2011, 12:15 AM | #230 |
I'm pleased to report my Shorai battery is working great; it cranks the engine hard, and my XR650L starts easily. Several days ago I installed an XR600R, left side cover.
I now consider my Shorai battery relocation to be complete. Spud
03-18-2011, 12:36 AM | #231 |
It looks great Spud. Less "L" and more "R" all the time.
03-18-2011, 01:01 AM | #232 | |
Removed SMOG tumors: 2 pounds, 4 ounces Removed engine guard: 2 pounds, 8 ounces Removed passenger pegs: 1 pound, 8 ounces Removed stock tail light: 2 pounds Removed steel fuel tank and “elephant ears:†5 pounds Relocated Shorai battery: 9 pounds Added luggage rack, and skid plate. Total weight loss: approximately 18 pounds I am going to install an FMF, Hi-Flo, exhaust header, which might shed an additional pound. I am also considering installing an FMF, PowerCore 4 muffler, which would drop another 2 pounds from the bike. Spud
03-18-2011, 01:07 AM | #233 |
Are you going to choose the FMF with the Power Bomb?
03-18-2011, 01:16 AM | #234 | |
I haven't decided to purchase the FMF muffler; I'm still trying to make up my mind about it. I really enjoy the low maintenance, and quiet operation of the stock muffler. However, some mud also bakes onto the stock muffler, and it is ugly. I would get improved performance, easier maintenance, and better looks from the FMF muffler. I would also shed another 2 pounds from the "pig" by installing the FMF, PowerCore 4 muffler. Spud
03-18-2011, 06:27 AM | #235 |
I would be remiss if I did not mention the Achilles Heel of the XR650L is its countershaft. :(
I frequently examine the countershaft splines on my XR650L. However, I admit, my eyes aren’t as good as they used to be. Advancing into middle age, I’ve acquired presbyopia. The last time I inspected the countershaft splines, they appeared quite good to my unaided eyes. Therefore, after I greased the countershaft splines, I took a few photographs, and went riding. :roll: However, I had noticed a hint of rust on both the countershaft, and the sprocket. Rapidly approaching 10,000 miles on my bike’s odometer, my nagging conscience prompted me to examine the photographs I had taken. Closely examining the macro photos, I thought I detected some countershaft spline wear. :? Therefore, I went outside, removed some grease, and examined the countershaft with a magnifying glass. Indeed, I discovered the countershaft splines were beginning to wear. 8O Closely examining the Parts Unlimited sprocket I had just removed, I believe I also detected some wear on the trailing edges of the inside teeth. :roll: I am determined to stop this wear! I also admire the great philosopher, Deputy Barney Fife. Therefore, I have decided to “nip it in the bud!†:twisted: XR650R, countershaft sprockets have 60 percent more contact area with the countershaft than XR650L, countershaft sprockets. I had planned to wait until my current countershaft sprocket needed replacement before switching to XR650R, countershaft sprockets. However, heeding the sage advice of Deputy Barney Fife, I now decided to act immediately! 8) I had shortened my drive chain to 108 links with my current 13T/45T sprocket combination. Therefore, I needed to acquire a 13T, XR650R, countershaft sprocket as quickly as possible. I did some research, and discovered I could obtain a 13T, PBI sprocket in 24 hours; I took the plunge. The photograph below confirms the XR650R countershaft sprocket has much more contact area with the countershaft than the XR650L countershaft sprocket. Mounted backwards, the sprocket teeth of the XR650R sprocket are 2.5 mm farther from the engine. Based upon the experience of others, I don’t think this will present a problem. In any event, I am perfectly willing to accept greater sprocket wear, and/or greater drive chain wear, rather than any additional wear on the countershaft splines! Remember Deputy Fife! I needed to tap lightly on the PBI sprocket with a hammer to allow me to install the sprocket retainer. Heeding a prior admonition regarding PBI sprockets, I examined the alignment of the sprocket retainer. The alignment isn’t perfect, but it should be robust enough. I went for a ride, and everything felt good. I will routinely inspect the drive chain, and both sprockets for unusual wear. More importantly, I am going to routinely inspect the countershaft splines under magnification to ensure I have stopped the wear, and “nipped it in the bud.†Spud
03-18-2011, 08:12 AM | #236 |
I wonder why Honda decided to use the thicker sprocket on the R and not the L from the factory.
03-18-2011, 10:09 AM | #237 |
Thanks for that report Spud. It would appear that the ultimate solution would be to mill 0.10" from the new sprocket to perfect the fit. Do I understand that correctly?
03-18-2011, 12:08 PM | #238 | |
In Andy's shop I picked up a pair of aluminum Moose bars last night. They were very light! :idea:
Happy to serve. |
03-18-2011, 02:57 PM | #239 | |
03-18-2011, 03:08 PM | #240 | |
Honda really should have redesigned the weak, XR650L countershaft. However, the cheapest solution for Honda would be to redesign the XR650L countershaft sprocket as you suggested. Fortunately, several XR650L owners have experimented with the XR650R countershaft sprocket, and discovered no unusual wear on the drive train. Apparently, enough free play exists in the drive train for one to safely employ an unmodified, XR650R countershaft sprocket. I would strongly encourage all XR650L owners to remove the XR650L countershaft sprocket, and substitute the beefier, XR650R countershaft sprocket. Spud
