01-11-2016, 12:49 AM | #211 | |
01-11-2016, 04:56 PM | #212 | |
So maybe the CSC and the AKT engines are built/selected to fit the economy (buying power) of the corresponding country. Higher income countries receive more advanced and more expensive products. Like the fuel injection/carb differences in the RX-3s in USA and Columbia. |
01-11-2016, 06:35 PM | #213 |
I believe AKT chose a carburetor for their TT Adventour 250 (RX3) because of poor fuel quality in Colombia. However, choosing a carburetor also reduces cost in countries where emissions standards are not as stringent.
The CSC TT250 is manufactured by Zongshen, and has a Zongshen engine. Some, perhaps all, of the Hawk bikes have engines from other manufacturers, and none of the Hawk bikes are manufactured by Zongshen. Apparently the Hawk version sold by AKT in Columbia is either not manufactured by Zongshen, or AKt selected a Zongshen engine without the counter balancer.
01-12-2016, 10:47 AM | #214 |
It might be a maintenance decision. A counter-balancer takes an anvil-simple design and adds complexity, and eventually repairs.
01-12-2016, 12:14 PM | #215 |
balanced
Weld, wouldn't the extra mass spinning round act a lot like a larger flywheel? I can see it working for the high rpm road guys, but for near trials like trail work over rough country, seems likely the reg motor would give a bit snappier torque performance when u need it. imho. 6assuming the specs given are accurrate, big assumption, the zong motor looks tuned for higher rpm hp w lower bottom end torque, while the hawk motor looks setup for bottom end torque and less high end hp. i can tell u from riding the hawk, for a 250, its a stump puller down low. i think the some storms have that balanced zong motor. I'd be interested in hearing what they think.
01-12-2016, 03:12 PM | #216 | |
01-12-2016, 06:48 PM | #217 |
Is the Zong counter-balancer chain or gear driven?
Why would the counter-balancer on the Zong engine be maintenance intensive?
Is it gear driven (steel teeth engaging steel teeth) or chain driven (sprockets and chain)? If it's gear driven what is the additional maintenance required? If chain driven, is there a tensioner that needs periodic adjustments or replacement? And what is the frequency of such adjustments? Just curious. I would still go for the inclusion of a counter-balancer in the engine of my bike. Vibration free smoothness is nice, especially on long distance journeys. |
01-12-2016, 07:09 PM | #218 |
It all boils down to what are you going to do with the bike. Not very many things work perfect for all applications. I would probably go for a ba!ancer engine for sustained highway use and non balancer for trail riding.
01-13-2016, 11:11 AM | #219 |
I hadn't considered that. Off the top of my bald head, I'd figure that the counter balancer would spin in the opposite direction of the crank (hence the name). Perhaps that would negate the extra mass. Dunno.
01-13-2016, 11:14 AM | #220 | ||
01-13-2016, 11:29 AM | #221 |
additional inertial mass such as a heavy flywheel will improve torque but slow the responsiveness. it might be a little less rev happy, you'd have a more noticeable effect from lighter rims and tires. than from dropping the balance shaft.
01-13-2016, 02:00 PM | #222 |
The Lifan and other CG clones with a balance shaft are gear driven. In order to do that the manufacturer had to move the oil pump down out of the way and drive it with a small chain. After over 50,000 miles that chain is worn on my Lifan 200 and I have been unable to find a replacement. Probably not many people put that many miles on a small bike so I would't let that influence my purchase decision.
BTW my Zongshen CG200 non balance shaft engine is nearly as smooth as the balance shaft Lifan CG200. The reason could be the Zong engine's bigger bore and shorter stroke. |
01-14-2016, 12:51 AM | #223 |
Thanks for chiming in, Mudflap. I couldn't recall who had the chain issue. Thanks also for setting me straight that it's the oil pump drive chain.
01-14-2016, 01:49 PM | #224 | |
01-14-2016, 09:58 PM | #225 |
Just saw an update on the CSC blog on the TT. Says production slated for early March. Not looking good to pick the bike up in mid March after the RX3 Baja ride.
http://californiascooterco.com/blog/?p=19601 Also looks like the Columbia headlight cage will be made available soon for the RX3. Rojo
'15 RX3 (Rojo's) '15 RX3 (marzhere's) '16 TT250 |
