#196 | |
I heard they compiled all his stuff into a multiple CD set...love to get it. Not sure on the long rods but I would say that would force a re balance for certain. You have any idea what those heads cost me?? ![]() On the beast, Im saying I break down before the beasts spark starts breaking up, or it goes into fuel starvation. Gets too scary. If I kept going I would expect spark to crap out first OR the motor would grenade. I dont think I've hit the fall off point of the cam yet and I know what that feels like cause I've done it in lower gears.
Good, Fast, or Cheap....Pick Two. |
#197 | ||
Re: MIKUNI CARB UPDATE
![]() Gawd, try putting that storage case on the back...the handle, the bloody handle makes your machine sound like a coffee can full of screws driving past. Yes, bucket on (harder to identify). "Man killed by Chinese ATV" would look pretty shoddy in the paper I think, although since I expect it to spontaniously burst into flames at any moment anyway, I could save on the cremation. Great post, thanks ![]()
#198 | ||
I didn't know about Smokey's stuff on CD, but I have Power Secrets. Excellent read. He claimed (as has Hot Rod and Car Craft) that a longer rod created a longer dwell time at TDC, thereby maximizing on the available compression. Fascinating. The only part that freaks me out is shoving the wrist pin up into the oil scraper. I think that a long rod anything should only be built with a tall deck, so as to not compromise piston longevity. I figure that Vortecs could out-flow the old 2.02 heads, including camel humps. Heck, they even outflow the Bow Tie 23 degree heads from the performance catalogue a few years back. The limitation to stock Vortecs is lift, but that can be overcome by machining the guides down a bit. Good to hear that your Beast is fast enough to be scary. ![]() All I meant by the 750cfm comment is that a 327 can't consume 750cfm mathematically. Doesn't mean it won't run strong. 8)
#199 | |||
Could probably put some stiffer valve springs in (Walmart sells mini slinkys) but then a keeper or something would break no doubt. I'm trying to cover with humor because I never thought of it ![]() ![]() Math? Meh..dont confuse me with the facts ![]()
#200 | |||
Stiffer springs with these little valves and keepers? Yikes, I value my fingers more.. |
#201 |
Well, I had a Cyclone Spoiler and I'd give me left nut to have that back....
Sorry...hows the beast run with the Mikuni on it? Any chance of a pic of the UNI so I can see exactly how mine isnt going to fit? ![]() EDIT: When mine blows up I'll spoof my IP and order a black 250 Zongshen from the guy. Think he quoted me 200 once (before he got to know me). Looks identical except WAAAY cooler cause its black. Oh, maybe a smidgen more TQ as well because of displacement. Who knows really. Pete
#202 | |
To be honest, it took us quite some time to get the thing to run with the Mikuni. We think there was a hunk of shit blocking the fuel flow somewhere, ended up messing around a lot, then finally taking the carb off and took it all apart to blow air through all the passages. When we put it back on it finally fired up. This was at end of day today so not a lot of time to play with it, plus with no back wheels couldn't take it for a burn up his steet. There is a still a racing idle problem, W&G thinks it's the throttle cable routing, that it's not relaxed enough in it's current path. We'll need to re-route it. (I have a feeling WE won't happen, as now as it's sitting over there I don't think D's going to be able to control himself to leave it alone) ![]() We did carve out a bit of an arc in the plastic to allow the UNI more room. Perhaps W&G can snap a photo for you. |
#203 | ||
Its funny how often I've read about just taking the thing apart, putting it back together and it works. In any case, glad it did. Speaking of the cable, one thing that maybe got overlooked (doubt it, but still..) is the cable adjuster cranked all the way down? (up actually). I can get my beast to idle at 3 grand if I adjust that thing all the way. With my batt size & box I am slowly accepting the fact that I need to section my intake tube. We have a pretty good welder and he can do aluminum. It'll be a case of beer, but I may have no choice. Found my rear wheels loose today. Cotter pin was holding the castle nut on. They got tightened with a 1/2" drive this time ![]() Looks like you 2 will be riding by next weekend, good stuff!
#204 | ||||
![]() Was the black 250 Zong intended for the Bad Boy atv? If it was intended for a dirt bike, then you'd lose reverse. Only an inconvenience I know, but I'd miss it. Maybe a hybrid is in order, using the big bore cylinder on the 200 bottom end. Quote:
![]() The cable adjuster is something I'll examine again, but the bike will idle ok. When you blip the throttle, it takes about three seconds for the idle to come back to Earth. I remember a similar problem with my Beast, prompting me to route the cable to the right of the tank with a more gentle radius. If you need to section the intake, consider correcting the weird offset. If you look at it from the top, it points off towards the exhaust. If you view it from the side, it's angled uphill and not even close to level. I realize that the manifold needs to climb up to the carb, but there seems to be no reason that the carb can't be level. I tighten the rear wheel castle nuts until there's no play between the wheel and the axle. They've remained tight in that position, with a little help from the cotter pin.
#205 | |||||
I had them snug before, but with this level of material/workmanship I'm always very aware of A>snapping or stripping something B>breaking my knuckles or fingers yet again when the bolt head twists off for example. That intake is really weird eh? Just finding a point to section it at will be fun, but thats a last resort. I have to have a real good look-see first.
#206 |
If you tighten the rear wheel castle nuts to the point where there's no play, yet the castle nut won't line up with the hole, shim the nut with a washer. Worked like a charm for me.
That precludes you from putting 100 Pete Pounds into it.
#207 | |
![]() ![]() I'll be able to let you know how it runs after I re-route the throttle cable and try out the new exhaust in the "Fun with TurboT's Gio Beast" thread.
#208 |
Ah, thank you.
I am moving the battery, it's the path of least resistance. I have a good idea too ![]() So you guys held out on me with that pipe I see...dangle the Monster idea and see if Pete bites....check it out, then go one better huh? ![]() Will go have a closer look at that pip sq.., er, pit bike pipe later. Thanks again for the pic
#209 |
Are we that transparent?
#210 |
Saran wrap's got nutthin on you two boys
