#196 |
Looks great Dan, your level of patience far exceeds mine. I don't think I could hold out that long without a quick spin around the block
#197 | |
Also, believe me, this is testing my patience. However, I learned a long time ago that doing it right the first time is the only way to do anything. If that means it takes longer, then it takes longer.
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 07-15-2018 at 06:30 PM. |
#198 |
I like how the air filter mod came out.
#199 | |
![]() Starting in my mid to late 30's, I slowed down on projects and started doing more intensive detailed work to prevent future problems. I used to be bad about, "That can wait until next year when I change tires" or some such nonsense to validate my excuse for not doing something I should do. Now in my early 40's, I just do it. I'm learning to switch off and just do it. |
#200 | |
Once I can tweak it a little more I think I will like it. I want to shorten up the metal exhaust tube I used to mount the filter, it's about 4 inches long and really only needs to be maybe 2 inches long tops. That will let me shorten up the elbow a bit more and get the filter closer to the motor.
This was kind of a proof of concept for me, and to give me an idea of what will work and what won't. Once I switch to a larger carburetor, I will be doing the same thing. In fact if anybody is interested, this is the elbow I used. Nice and cheap. https://www.ebay.com/itm/1-75-1-3-4-...-/263148564068 Quote:
#201 |
Thanks for the link. I was going to ask you were you got it from. I'm going to need something closer to 1 7/8" id. But that gives me a place to start looking. I think I'm going to cut a round hole about a inch bigger than my pod filter so I can put the filter in the air box and will be protected from mud and water slinging on it.
#202 | |
https://www.ebay.com/itm/Black-45-De...sid=m570.l1313
#203 | |
#204 |
Would it be possible to drill a hole in the air box and run the tube inside and then put the filter on? My thinking is the airbox would act as a splash guard. The top of the box could be drilled for more intake air and a small hole or three in the bottom to allow any water that gets in to drain back out.
#205 | |
#206 |
Well my MCO finally got shipped out today via Priority Mail, so as long as they don't screw up anything with the paper work, hopefully I will get it in Friday and I can register it.
#207 | |
Dan, where did you get the pump carb, and what brand is it? I origially bought a Keihin, but was sent a Youall brand. The pilot jet that came with mine does not match anything I can find, but the main jet seems to be easily found. Did you check out the pilot jet on yours? Doug |
#208 | |
#209 |
Might as well update. No new progress, but I do have all of my parts in. Now if I could just get a day off I might be able to finish it.
Got my MCO in today as well.
#210 |
----------------------------------------------------- "Take it easy, if its easy take it twice" 2015 CSC TT250 -Ebay exhaust -Exhaust wrap -Wingsmoto Air bent filter (POD) -Outerwears prefilter for POD -CSC jets 115 and 40 -15 weight front fork oil -47 tooth JTR269.47 rear sprocket -JT 428 HDR (128 link) Heavy Duty Drive Chain -LED tail light bulb -Auxbeam LEDF-S2 headlight bulb -Brush hand guards -30L removable tail box (ebay) -3.1amp waterproof usb charger |
