#196 |
I tried to translate that page, but I'm still struggling to understand the origin of the engine. I know that it's made by Zong, but is it a Honda copy? CRF perhaps?
#197 |
That I do not know , in appearance seems to have the CRF mounting locations. different head than a unicam CRF
#198 |
How well did the NC250 engine work for you, Racer? Did you ever have any problems with this engine?
#199 | |
![]() The NC250 engine has a single, overhead camshaft. This engine has two intake and two exhaust valves. The centrally located cam actuates the valves via two roller rocker arms. ![]() My CRF250X engine has the camshaft located directly above the intake valves. The Honda engine actuates the exhaust valves via a roller rocker arm. The Honda engine employs a shim-under-bucket design to adjust the intake valve lash. The CRF engine uses a shim-without-bucket design to adjust the exhaust valve lash. The shims rest directly on top of the valve retainers, and are directly contacted by the rocker arm. The NC250 engine employs valve tappets to adjust the valve lash. ![]() ![]() My Honda CRF engine has a five-speed transmission. The NC250 engine is available with both a five-speed, and a six-speed transmission. The ZS250GY-3 employs the six-speed transmission. ![]()
#200 |
My Honda CRF engine has the spark plug located centrally, between the four valves. You must remove the fuel tank to replace the Honda's spark plug. The NC250 engine has the spark plug conveniently located on the right side of the cylinder head.
#201 |
No problems with the engine or trans shifting . seemed to be a very solid package . I do hope the gear ratios were changed . First gear seemed a bit high ,even in the megelli . The megelli had no dreams of off road riding.
#202 |
Thanks for the good report, Racer.
#203 |
The NC250 engine also has a different bore and stroke than the Honda CRF250 engine.
Zongshen NC250 Engine Bore: 77mm Stroke: 53.6mm http://yitonmoto.en.alibaba.com/prod...ine_NC_CB.html Honda CRF250 Engine Bore: 78mm Stroke: 52.2mm http://www.hondanews.com/channels/po...specifications The Honda piston has one compression ring, and a very short skirt. The Zongshen piston has two compression rings, and a more conventional, larger piston skirt. ![]() ![]()
#204 | |
![]() Last edited by recracer; 09-17-2014 at 04:28 PM. Reason: add chart |
#205 |
Later, I am going to read your complete thread for a second time.
#206 |
I have heard reports Zongshen promotes the RX3 as having a Pro Link, rear suspension. The lower shock linkage doesn't have any grease zerks, so it will need to be disassembled for periodic greasing, inspection, and bearing replacement, as with my Honda CRF250X. I am trying to verify the sizes, and the availabilty of these RX3 bearings.
#207 |
Where is the oil filter located on the Megilli NC250 engine? How did you turn the crankshaft to inspect the valve lash? The bottom end of the NC250 engine is quite different from either my CRF250X engine, or the CRF450X engine. The NC250 engine really looks like a new Zongshen design, and not a copy of another engine.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." ![]() 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 09-18-2014 at 04:39 AM. |
#208 | |
#209 |
Thanks for information.
![]() I see a timing check hole on the stator cover for the NC250 engine, but I don't see a plug covering access to the crankshaft. I'll look more closely, later. ![]()
#210 |
