#181 |
A little over 400 miles. Mostly singletrack so slow speeds. I'd estimate around 16 hours and I'm not going easy on it at all. Loads of steep hillclimbs banging it off the rev limiter, etc. |
#182 | |
That is good to hear! The little extra pep is just what this motor needed as far as I'm concerned. If I wanted way more power I would not be on a 250. It's really made the bike enjoyable to ride without being too much. It is now squarely in Goldilocks territory and 'just right'. . Last edited by ChondaChondaChonda; 05-31-2018 at 10:57 AM. |
#183 | |
![]() So if one person has an engine grenade the kit's not worth a crap. I don't get it. ![]() Chonda, Keep posting. I enjoy reading your threads. ![]()
#184 |
Whoops. My error.
Chonda has whipped his like a bad mule and it's still hanging in there. That gives me faith.
#185 | |
That was my opinion pretty much (RZ3), just a bit fuller power rather the 'just enough" I am now on my second upgrade on my own RX3 as well as big front brake with 4 pot caliper |
#186 |
Got home yesterday with every intention of putting more miles on the 300cc kit. Walked in, unloaded my lunchbox, made the grave mistake of hitting the couch to watch the weather, woke up two hours later. Hate that.........
#187 |
Hate it when that happens lol
#189 | |
#190 | |
I might. It depends on if a truck and a motor I have for sale goes quick enough. 8hrs would be ridiculous. I'm sure I can do it in 2 hrs. It's simple straightforward as a swap can be. These bikes are super easy to work on. |
#191 |
Hate it yes... Then again we've earned that privilege !
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
#192 |
Grew up in the olden days when bikes had just what they needed to get down the road. RX3 is more style than practical parts, taking hours to figure how to get all the useless crap off to access the hardware. Bolt sizes don't match in the same pattern on a single part. Just one step at a time, probably take 12 hours labor or more. Used to rebuild 4-stroke singles on 1 1/4 hour with premachined parts.
#193 | |
Yeah, the LXR and GPX are much easier to tear apart. |
#194 |
Anywho, back to impressions of NZ's kit:
Comes with the basic RTC kit: Cylinder Piston Pin Clips Rings Base gasket Head gasket Added by NZ to provide a complete kit: Rocker arm cover seals Inserts for alignment between cylinder and case, between cylinder and head Oil screen, copper washer, and o-ring Oil filter, wire mesh reusable type Left side cover gasket Cam chain tensioner gasket O-rings 90101-30175000180 No idea what for, need to thoroughly exam parts removed from engine. Guessing plugs that cover timing marks on left side of engine on cam sprocket. 2 exhaust seals, 1 copper, 1 steel/asbestos. NZ, looks like a perfect kit for the carb models you have. Only additional seal/gasket not included is intake manifold to head. With a carb it would be easier to leave the manifold attached to the head and pull the carb loose from the plastic tube. Might be so with the EFI, but I'm polishing the ports, so off it comes. Don't know if the carb versions get the same seal. Short the intake/head shaped o-ring seal for EFI versions, but mine is a 2015 model, off the first container to arrive, and that particular part is still in excellent shape on my RX3, so not really necessary. Anywho, CSC describes the part as "O-RING 38x3 Part #: Z10-112" and price is $1.45 plus shipping, which will probably run about $12 unless you buy $98.56 worth of other goodies at the same time. Now do you see why your extra efforts are so valuable to us? Anywho, the part speced for carb manifolds is also described as "O-RING, 38x3, INTAKE MANIFOLD" and I believe the part number is 90101-30380000300 if you want to include that. The side case cover gasket you included is not needed on my specific model because I choose not to remove that cover. Too many tidbits on the RX3 to worry about pulling the left crankcase cover, so won't be using that gasket. Again, might be needed on different models, I'm guessing carb versions? Again, good job building a complete kit. So convenient for us. |
#195 | |
The O ring at the manifold is hard to get, nothing online and the dealer can be 10 days to never to get stuff. Funny thing is CSC on stuff can be easier then local here in fact and on small parts its not much more then here etc. Left side cover is cause it is easier to manage the chain etc, but to be fair I reuse the gasket as they didn't break in the past but hey it might be useful another time worst comes to worst. RX3 you need to remobe the frame around the engine and drop the bolt under the engine near the swing arm put you tongue out left then right whistle and fart a moment for the bits to come up and out as that metal bar gets in the way etc Mine is together - needs oil and test start after I fit the FOG HORNS for safety. |
