#181 |
I ordered a new swing arm for my Hawk today! I don't know if it is state side or if it has to take the slow boat from China.
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
#182 |
Bought the exhaust system and the Mikuni VM carb, now it comes the hardest part...
#184 |
Took a ride out in sweltering humidity in search of some good back roads and some gravel roads I'd found on Google maps.
![]() Had fun on light gravel but chickened out when the road was interrupted by a berm and a lot of mud and weeds the other side of it. If I was with someone I think I'd like to have a go at it some other time: ![]() |
#185 |
Took the TT250 out in search of some back roads and a gravel road I'd found on Google Maps. It was very hot, I think the hottest weather I've been out in on the 'Zong.
![]() The gravel was fun and actually no problem at all, but ended in a berm built up over k-bars blocking the way with a lot of mud and weeds the other side, so I chickened out. There's definitely a trail of sorts there - it is marked as a road on the map - and next time I'm out with someone I want to explore it further. ![]() |
#186 | |
Any help is appreciated. E |
#187 |
#188 |
I took the Hawk and the rest of the stable out for 6 hours of exercise Sunday in 92+ degree heat. The morning started off with a flat on the front so had to patch it before we left. We got to the spillway and started unloading the trailer. My wife undone one of the straps on the bike before I could tell her don't do it. Bike fell over on it's side and almost smacked her in the head.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 07-10-2017 at 11:39 AM. |
#189 | |
#190 | |
#191 |
The second one I built is made out of 1/4 inch aluminum plate and better looking.I will post some pictures and blueprint numbers for the first one I made the one you posted.
#192 |
Found an oil leak! looks like it is located underneath the starting motor
#193 |
Are you sure it's not just chain oil?
#194 |
Nope, it is engine oil, weird thing is that it leaks just a few drops when cold starting and then a few minutes sitting after a ride
#195 | |
Pic?
