#181 |
Looking forward for the new design too
#182 |
Can't wait to see it.
#183 |
So this is another style they sell in China. It replaces the oil plug and screen. Only $5 difference in price but hoses cannot be cut to length. I am ordering 1 of them to see if it will work out. I'll try to fit it on my bike. Their is a possibility of cutting the crimp off the hoses on one end and using a hose clamp like the ones i have currently.
#184 |
I actually like that better. I assume that is a filter in line?
#185 | |
#186 |
Yes that is a filter.
#187 |
Diggin' it. Mrs. 2LZ TT250 may need one of these.
#188 |
This one looks interesting keep us posted.
#189 |
I hate to say it, but I think an oil cooler will do a whole lot of nothing using that configuration. If you think about it, you'd have to literally have the hoses and cooler filled with oil and the oil be continually moving before any cooling can take place. How's the oil pump up into the cooler? I know the crackcase gets pressurized, but would it be enough to push the oil through the cooler? It may do more harm than good. I could be wrong though.
I wonder if the instructions say that more oil needs to be added once the unit is installed? |
#190 |
Whoops! Didn't realize you were designing it.
My questions are - do you need to add more oil to compensate for the oil that's supposed to be in the cooler and lines? How is the oil getting pushed through the cooler? Assuming the drain port has a push and draw setup Is there enough pressure to get the oil up there? Just curious On the hand guards - count me in Last edited by rwl6935; 04-05-2017 at 09:13 PM. |
#191 | |
I have been running one for the last 200 miles. It warms up right away. According to my supplier they send a bunch of them to South America and the desert areas of China. I know it helped my hot shifting..... |
#192 | |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 04-12-2017 at 08:12 AM. |
#193 |
in place of the oil screen eh? that means it would cool all the oil being fed to the engine not just a portion of it?
#194 | |
#195 | |
