Old 04-26-2016, 12:40 AM   #181
Originally Posted by dpl096 View Post
I just don't recall Joe or anyone else mentioning this issue in the 5@8 book or any of the video interviews.... Is it across the board or an intermittent issue?
I guess you missed it. Perhaps you have more to learn. Have you seen the following video? In particular, pay attention to the information starting at the 12:32 time stamp.
Old 04-26-2016, 12:40 AM   #182
As we know about production line work, literally 100's of units could be incorrectly fitted, especially something so inconspicuous. I assume SCS and the factory has been informed? Fuel-ly oil, not good.
Old 04-26-2016, 01:04 AM   #183
It's not something I worry about, since it is so easy to flip the OCS.
Old 04-26-2016, 08:01 AM   #184
dpl096   dpl096 is offline
dpl096's Avatar
Thanx!
― Thomas Jefferson
Old 04-27-2016, 11:13 PM   #185
DoomWeasel   DoomWeasel is offline
DoomWeasel's Avatar
Well I was near 400 miles on my '16 RX3 and decided to change the oil for the first time. What did I notice when I was face level with the OCS? It was upside down. So I flipped it so the hose was above the clamp. So this still seems like something everyone should check on their bike when they are delivered.
Eric
2016 CSC RX3 Sahara Orange
Old 04-28-2016, 08:22 AM   #186
Inroads   Inroads is offline
Fuel psi drop test
Here is the procedure outlined by Gerry at CSC for detecting a leaking injector:
Connect a fuel psi meter to the fuel line
Start the engine
Fuel psi should increase and maintain psi as engine is running
Turn engine off
Fuel psi should hold 80% of its value for at least 20 minutes
Checking the fuel psi drop is the best way to determine if you have a leaking injector.
I will relay my findings when I do my test.
Old 04-28-2016, 08:25 AM   #187
Start the engine
Turn engine off
Please do keep us updated. I have been hoping for quite a while that you can resolve this problem.
Old 04-28-2016, 12:27 PM   #188
rjmorel   rjmorel is offline
rjmorel's Avatar
Is the psi meter you use to check this a generic one that works on all fuel injectors or do you need a special for the RX3? thanks rj
Live Zong, and Prosper
Old 04-28-2016, 12:54 PM   #189
Pressure leak down test, seems simple enough. In line generic, oreilly auto p. Part #1654 no $ found guess it depends on what and where to connect.
Old 04-28-2016, 12:59 PM   #190
dpl096's Avatar
Start the engine
Turn engine off
Hoping this is a simple injector issue for you !
― Thomas Jefferson
Old 04-28-2016, 01:57 PM   #191
That pressure gauge only seems to read 15 psi, which is not high enough.
I bought a fuel injection pump pressure gauge from eBay.
http://www.ebay.com/itm/New-Fuel-Inj...395178&vxp=mtr
Old 04-28-2016, 02:29 PM   #192
dpl096's Avatar
23 bucks !
― Thomas Jefferson
Old 04-28-2016, 03:35 PM   #193
rjmorel's Avatar
OK ,Im a noob on FI. Where do I connect said gage? Inline between fuel pump and injection nozzle or in tank on suction side? I'm really not familiar with the underside of my RX3 tank. There be monsters in there, Rj
Old 04-28-2016, 05:10 PM   #194
To perform a leak down test, you connect the pressure gauge inline, between the fuel pump and the fuel injector.
Old 05-02-2016, 12:06 AM   #195
Rodtheviking   Rodtheviking is offline
Rodtheviking's Avatar
Found this on both of ours, upside down.
2016 CSC RX3 Silver
