04-12-2020, 08:58 AM | #166 |
As long as you have a good large snap ring pliers it can be done less than a 30 minutes. That snap ring is a mofo to get off an on without the right tool but can be done. I used my rotary tool to grind the pins off to remove links from the chain. It probably took me about an hour for the whole process.
04-12-2020, 09:28 AM | #167 |
I don’t have any, but I’m going to run by Harbor Freight today to see if I can buy some and also a spanner wrench.
This bike definitely take some tinkering and sorting out to tailor it to the individual rider and their needs, but it’s really turning into a nice bike and it’s such an amazing value. Plus, I love having a project and researching mods. I let my best friend ride it who also used to ride bikes back in college. He was surprised at how much midrange juice it had and he didn’t even go wide open throttle. Of course, I made sure to lower his expectations by letting him know it has 5 less hp than my riding mower. lol
2019 Venom X22R K&N pod air filter, removed cat, 105 main jet, 36 tooth rear sprocket, RK racing 428 chain, oil cooler, NGK plug, bar risers, aftermarket mirrors, Grab On grip covers, phone mount/charger, Pro Grip tank protector, Chase Harper tank, tail, and saddle bags. |
04-12-2020, 09:36 AM | #168 |
I forgot to mention, my first tank of gas that I calculated the mileage came in at 54mpg. That was 3.5 gallons used over 189 miles and the tank had quite a bit left in it. The tank is rated at 4 gallons, but it holds more than that. I’m estimating 4.5 gallons counting the reserve. I put 4 gallons in it the first time I added gas and it wasn’t all that close to the top of the tank.
That mileage includes ripping around at 3/4 throttle or more in stop and go traffic and one country ride down some 2 lane at 55-60mph. I have no doubt I’d see 60+ on the highway, especially after I change this sprocket Monday. That’s a huge improvement over the 9-10 city and 14 mpg highway my 4” lifted Hemi Ram on 35s gets and it’s how I justified the bike’s purchase to myself.
04-12-2020, 09:36 AM | #169 |
I have the HF snap ring pliers. They just barely get the snap ring off but worked. Just took a little patients.
04-12-2020, 09:40 AM | #170 |
The tank takes 5 gallons. I filled mine yesterday and took 4.4 and didn't touch reserve. I've been averaging around 65 mpg. My first tank was 58 mpg. That probably because of the high gear ratio.
04-12-2020, 09:40 AM | #171 |
I have patience and Corona Extra. I’ll happily sit out in my garage and drink a few beers while I figure out the pliers and sprocket.
04-12-2020, 09:43 AM | #172 | |
I love hearing about that gas mileage with the new sprocket. Bringing the revs down from 7000-7500 to 5500-6000 has to improve economy at 60-65 mph.
04-13-2020, 08:13 AM | #173 | |
04-13-2020, 10:56 AM | #174 |
I wasn’t able to ride my 110 or so miles this weekend due to storms, but I did ride it to work this morning. It feels a lot different with the risers. I have my bars at too much of an angle and I tried my clutch lever angled down a bit more than I had it, but I’ll widen out the bar angle and raise the clutch lever a bit this afternoon. I think I’ll appreciate the raised bars on my longer rides as the ride to work is only 2 miles.
I’m going to knock out that sprocket install tonight. I bought the best snap lock pliers Harbor Freight had and they look pretty beefy. I’m going to hang my bike from the rafters using some ratchet straps like you did, Jerry. I need to go ahead and buy a bike stand and swing arm dowels so I can drill and tap some holes on the swing arm and install them.
04-13-2020, 11:02 AM | #175 |
We lucked out and all the bad weather just missed us.
I ended up buying a Swing arm stand form HF about two weeks ago. It made my chain maintenance much easier. lol I contacted HF to buy the front fork adapters but was told they were discontinued. I did find them on Ebay but was only available from one seller in Italy. I might have them for the weekend or next week. https://www.ebay.com/itm/Paddock-Sta...t/173309301184
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 04-13-2020 at 11:42 AM. |
04-13-2020, 12:50 PM | #176 |
I like that Hf swingarm stand that won’t require me to buy and install those spools. I’ll pick that up today for sure for my project tonight.
I’ll also buy those adapters for the front. You sure are good at getting me to spend money on mods. lol I’m going to make a decision on where I go with engine mods after I run this sprocket for a week or two. At the absolutely least for short term, I’ll port and deck the head and go from the 3 layer stock head gasket to 1 layer. That’ll equal about 10.7:1 or slightly higher compression. That’s a 1mm or 0.04ish decrease from the decking and a 0.015 decrease from the gasket. Stock, there is 0.1 gap between piston and valves. This should leave plenty of piston to valve clearance. The head decking is worth about a point of compression and the gasket is worth around .4. It’ll require premium gas, but that’s ok. Then, over the winter I’ll likely go with the Athena 67mm piston kit with an 11:1 piston, a thin copper head gasket to take it to a true 11:1, which will take it from 223cc to 233cc, a new CSC head that I’ll port, some Kibblewhite valve springs, and either than Terry Miller 2.5 cam or the Webb 89A. Maybe the Web 40/402 cam. That’s about $900 is parts though not counting the new carb and intake manifold I’d need to optimize it. So, I’ll just raise the compression for now! lol
04-13-2020, 01:21 PM | #177 | |
The thinner head gasket sounds like it will work. I'm not sure how thick the stock gasket is yet. Now you got me spending money. The CSC TT250 head will not work on these engines. The TT250 is a push rod engine.
04-13-2020, 01:26 PM | #178 | |
Doh, I need to find a new source for a head then whether Chinese or a CRF230F. The other option is to do a Weisco piston for about $105 that claims 11:1, but is really more like 10.5:1, and then do a thin gasket to get the desired 11:1 compression. This is nice because it leaves the head stock so you don’t have to worry about piston to valve clearance with a big cam. The piston is domed, but not in the area of the valves so it won’t get in the way of a cam. The drawback is it appears you have to remove the engine from the frame to install it. Apparently the stock CRF230F gasket is 3 layers riveted together. People drill out the rivets and then just use the top or bottom layer for a half point compression increase. I’ve learned a lot about these engines on thumpertalk. They’re a fairly popular engine to mod.
04-13-2020, 01:57 PM | #179 |
I'm just going to port and deck the stock head. The CRF230F heads run $170-200. I ran across a chinese head for $90. You could probably order one from Venom.
04-13-2020, 02:14 PM | #180 | |
That’s a win win.
