#166 |
Obnoxious Mystery Noise
I found it!...and I wasn't even riding it!
In some of my earlier posts, I complained about a rattle or light knock or deep tap that I'd hear at certain RPM's under load. At first I thought it may have been an engine noise because it seemed to be coming from between my legs...but we all know how sounds travel and the CG motor is notoriously solid. Then my plastic license plate frame snapped off one evening on my nightly break-in ride and I thought maybe that was it. Shortly after, the bike came apart. Last night I was once again giving the TT a stare down after the brake bleeding....and I was checking the tank plastic wings to make sure that I had them on correctly. I wiggled and tapped on them before I checked the mount screws for tight...and low and behold..."TAP!" HUH? I hit it with my finger again..."TAP!" Wouldn't you know it!? On one of the lower slip-on mounts on the tank tab, right side....it was tapping against the tank! I took the wing off, slightly tweaked the tab toward the tank, remounted and it was gone. Now the wing is nice and snug to match the other one. No more tap. I know...this ain't much but man was it annoying. Just the wind catching it was making it tap against the tank at certain speeds and it was driving me nuts.
#167 | |
Previous: '80 KZ550, '04 Shadow 750, '12 NC700X Current: CSC TT250 |
#168 | |
Weird I think I have the same noise, I only hear it occasionally when I throttle hard. I shall check my wings tonight ![]()
2005 CBR600RR
2016 CSC TT250 Coming Soon |
#169 |
I used something similar to this hand held 'Impact Driver' on the 99 Kawasaki when one of the brake master screws gave me problems (the other one needed to be "Alden extracted")... a few light smacks with this tool and a hammer and the rusted in place screw came right out
https://www.amazon.com/TEKTON-2905-8...dp/B000NPPATS/ ![]()
"Think as you like... but this self proclaimed Professor is always right" - Buckshot ![]() "You never know what someone is hiding beneath their smile..." - NinjaTom - R.I.P. |
#170 | |
#171 |
If you have an HFT close by they have scads of them also for cheap. Don't forget your 20% off coupon!
#172 |
I actually have the 20% off coupon in my wallet now, along with a coupon for a set of screwdrivers free with any purchase over $5.something! Perhaps I'll ride up there today on my lunch and see what I can find. Just another opportunity to put more miles on!
#174 |
Emailed Ryan this morning. Screws in the mail. Man I love these CSC guys...........
#175 |
Detailing
Since I'm in Limbo waiting for the damn sprocket, I double checked some torque specs for my final report (hopefully soon) and generally went over the TT with yet another fine toothed comb. I decided that the plethora of little stickers all over the motor had to go, so I started pealing and de-gluing. Made the motor much more clean looking...and then I ran across this.
For you newbies out there, this is a prime example of "Perfect Chinglish". ;-)
"Light a fire for a man, and you heat him for a day. Light a man on fire, and you heat him for the rest of his life." 2007 Suzuki DRZ400S (SM convert) 2009 Q Link XP 200 1967 BSA B25 250cc Starfire 2022 Royal Enfield Interceptor 650 2023 Royal Enfield Scram 411 1948 Royal Enfield Model G 350 Last edited by 2LZ; 02-07-2018 at 12:06 PM. |
#176 |
still better than my engli-chin
#177 | |
#178 | |
#179 |
#180 |
This is my favorite line from the Roketa db-06 owners manual
1988 Kawasaki KLR250 1969 Honda Z50 silver tag 2002 Ford F-350 7.3 diesel 1975 Corvette 2017 Chevy Bolt “Throttle twisting geek” -LFN |
