#166 |
1988 Kawasaki KLR250 1969 Honda Z50 silver tag 2002 Ford F-350 7.3 diesel 1975 Corvette 2017 Chevy Bolt “Throttle twisting geek” -LFN |
#167 |
![]() My new XRL faring. I still think I need about 4 more inches tall windshield on it, to keep the buffeting down a little more. better than stock tho!
#168 |
I've been riding Roketa around for several days now, including 20-30 mile rides up the mountains on the logging roads. Suspension feels amazing! Bike handles very well. I think it has a somewhat relaxed head tube angle so cornering on gravel and etc. is not even an issue. Very stable. The Suzuki DR125 rear shock, for 35$ is exactly what was needed. The horrible oil filled Chinese shock will soon be in the bin... also, xr600 light assembly is working fine. I did hack/install the Roketa dual beam bulb, so all wiring hooked up. Looks and works exactly like I wanted it to. The bike is low and slow, but actually, secretly, maybe even more fun than my XRL on short trips (don't tell). It has a really wide turning radius so that's a downside to the design, and the seat is pretty hard, but over all, bike is perfect for tootling about on the short trips.
Also, bonus! I hated the rubber covered foot pegs. Well, what do you know, the rubber parts pop off and underneath are regular, motocross type foot Pegs! How strange! But awesome! So, footpegs feel and work fine.
#169 |
I wrote an email to the Zhongshen factory to see if I could find out any more information about this bike... will update if something is revealed
L
#170 |
Evidently, the reserve on the Roketa doesn't work too well... I've run out 2x now. and, flipping to reserve barely gets me a 1/2 mile. Luckily I've been that far away from a gas station both times, so coasted in. Hmmm...
#172 |
I've had various responses on the origin of the bike. Beta USA denies any collusion with Chinese companies. Second email I sent them pictures and then they just said "thank you".
Chinese bike sellers said it was a clone that was copied in many factories, but the one they said it was cloned from was a completely unrelated bike... so, dead end. But, as several others have said, gotta be a relationship. The Alp and the DB05 are too similar for coincidence. Got a good ride in last Friday, but was on the XRL. That's it! L
#173 |
Sooo, I drove the Chinese bike around yesterday. Now, after riding the TTR225 Yamaha for 9 hours in a day and then the Chinese bike, oh man, the Yamaha is soooooo much better. It's crazy the difference in comfort. Not to say the Chinese bike isn't ok, but, for long term saddle time I'm taking the Yamaha...
#174 |
Anyone dealt with the Chinese bike starter system? Solenoid will engage, but engine will crank slowly, or pause, and I'll re hit button and then it may or may not go. When it's hot, seems to be a little worse. I replaced the battery thinking it was the problem, same. I'm thinking solenoid? Or? Maybe starter brushes? I figure I'll see if the solenoid is able to be taken apart, and I'll clean the large contacts first.
#175 |
I'd try the solenoid first. You can test it if you like, by disconnecting the secondary side of the solenoid and measuring the in and out voltage. If there is noticeable drop, it's the solenoid.
#177 |
Did just that. Still cranked slowly, so, probably the starter. Wires got warm too, so yeah...
#178 |
I'm betting that when you order a new starter, you can also order replacement brushes for your existing starter. That'll ensure that you have a good starter on the shelf.
#179 |
I pulled apart the starter. Super simple. Nothing obviously wrong, but maybe the commutator was a bit more worn than it should have been. I cleaned it up, greased the greasy bits, Brushes were fine, and reassembled. I then noticed upon cranking that the negative wire was getting warm. It was also very long. I shortened it and reattached it to a closer case bolt. I also created a second one, and attached it to the frame. Is cranking much better now. Should be good to go until I can buy a Chinese starter off eBay some time in the future.
#180 | |
