Old 02-04-2015, 11:20 PM   #1711
Britster   Britster is offline
Zongshen RX3 in Philippines
Zongshen Philippines Business Manager: 'Noah Sun', is the guy that helped make the 'Zonshen RX3' available through Motorstar in the Philippines.
It is a special version for the Philippines, as follows:-
1) Standard Carburettor, rather than Fuel Injection.
2) Top Box and Panniers included as standard
3) 12V Power and USB Socket fitted as standard
5) SRP PHP130,000, available from Motorstar 10th Ave., wef 1st December 2014,
6) 0% Financing with 50% Deposit, Balance over 12 months
7) Top 10 buyers of RX3 Xplorer Z250R will receive this limited edition jacket as freebie from Motorstar and as distributed by Zongzhen
Not currently available from Motorstar Branches in Cebu, Philippines.
Old 02-04-2015, 11:35 PM   #1712
http://item.taobao.com/item.htmspm=a...ucket=2#detail
Considering the Zongshen RX3 (ZS250GY-3) NC250, sells on TaoBao:-
宗申RX3(ZS250GY-3) NC250 越野街车 个性摩托车 可店内上牌
价格 ¥19800.00
(with no Luggage Rack, Top Box, Panniers)
The SRP of PHP130,000 with 50% Deposit and Balance via 12 x Post Dated Checks,
CNY19,800.00 = 139,742.188 Philippine Peso, is pretty good price.
It might be Carb version rather than Fuel Injection (but less to go wrong and easier to troubleshoot and repair), but comes inclusive with Top Box and Panniers, and 12V and USB power outlets.
http://item.taobao.com/item.htm?spm=...ucket=2#detail
Perhaps this is inclusive of the luggage and 12V/USB Power outlets:-
Price is CNY21,800 which would be PHP153,821.859
Old 02-04-2015, 11:53 PM   #1713
Thanks for posting the information. Have the RX3 motorcycles been delivered to the Philippines? Have you bought an RX3?
Old 02-05-2015, 12:03 AM   #1714
3banger   3banger is offline
3banger's Avatar
Hey Katflap, sorry to hear about the tip over on such a new bike; I've been there it sucks. I've actually droped and crashed every motorcycle I've ever owned and I don't expect it to be any diffrent with this one. So how did it hold up to the little tip over? Any damage? How did all the crash protection fair?
Old 02-05-2015, 12:35 AM   #1715
Originally Posted by katflap View Post
Im 5'8'', 150lb of wind and piss .
Great line!
Should there be another unfortunate drop in the future, I recommend that you consider this lifting procedure:
Stand facing away from the seat, with your heels against it. Crouch down, find a place to grab with both hands and lift with your legs. If the bike fell on the right side, pop the kickstand down first, so the bike has something to land on.
If the bike fell on the left side, be careful to not push it over.
Old 02-05-2015, 03:06 AM   #1716
Spud, there was advanced orders the 1st 50 off RX3.
These were then available from Motorstar Branch on 10th Ave in Manila, I believe.
The price is PHP130,000 (USD2,496)with 50% Deposit and Balance via 12 x Post Dated Checks,
I was working in China (Changsha, Hunan), so I could not place an order. No deliveries to Cebu by Motorstar (which is where I live and here currently for Spring Festival break)
https://www.facebook.com/groups/zons...96627250366110
https://www.facebook.com/groups/730916903631862/
Old 02-05-2015, 05:16 AM   #1717
Motostar offered a good deal. Will the price rise for future orders? Do you plan to remain in Cebu? If so, do you plan to order an RX3?
Old 02-05-2015, 01:49 PM   #1718
NoVa Rider   NoVa Rider is offline
Katflap pointed out that in the UK, the RX-3 is equipped with a spring loaded sidestand, since it does not have a sidestand kill switch.
Does anyone know what CSC's bikes will be equipped with? I think the US also requires some kind of system to prevent riding off with sidestand down.
Old 02-05-2015, 02:23 PM   #1719
My Honda XR650L has a safety switch on the side stand, but my Zongshen ZS200GY-2 does not. I can't recall seeing a safety switch on the side stand in any photographs of the Zongshen RX3.
I don't believe this safety switch is mandatory in the United States. I have read this switch is mandatory in Canada, but I haven't verified that information.
Old 02-05-2015, 03:07 PM   #1720
I've never heard of a mandatory kickstand safety switch in Canada. Doesn't mean it isn't so, but it would be news to me.
Old 02-05-2015, 03:36 PM   #1721
katflap   katflap is offline
katflap's Avatar
@ G19Tony -----Spanner sizes –
Rear axle21mm both sides, alignment adjusters 13mm
Front axle 19mm one side. The other side, protruding round shaft with aprox 8mm hole through the diameter held tight by 2 x 10mm fork pinch bolts.
@ jimjr21 -----
I will remember your photographic tip for the future, thanks.
It was a shame because there really was a fantastic view from there.
@ SpudRider ----
My bike came without the cush hub which would have been a nice addition .That said I’m not finding it uncomfortably snatchy
The rear sprocket seems to match the JTR 897 – 44 but no good for the cush hub version but this link shows that it’s still using a 44 tooth sprocket
http://2.taobao.com/item.htm?id=43664671492&spm=a230r.1.14.279.wdjGJj& ns=1&abbucket=8#detail
The front sprocket has 14 teeth with a flange on the inner side. It is secured to the shaft with a bolt and lock washer. The outer side has a hole to one side of the bolt where a small tongue from the lock washer fits in to. The lock washer has a tab that is bent up against one of the bolts flat edges to hold it in place. Im sure you know the sort of thing it is.
Sorry I can’t give you shaft and spline details at the moment but I want to make sure I can get a replacement lock washer before I start taking it a part.
I will re check the teeth number and get back to you because this link shows the front sprocket having 13 teeth.
http://item.taobao.com/item.htm?spm=a1z10.5-c.w4002-7242439086.119.ZmWXGG&id=39099439130
@ 3banger ---
Thanks for the morale booster; I will try not to make dropping the bike a regular thing.
The bike had a soft landing because I was pretty much underneath it!
But the screen broke when it hit my rubbish wheelie bin. It’s now back on the bike but looks bloody awful where I have glued it back together. A new one is on order!
@ Weldangrind -----
I will definitely take your advice on lifting the bike in the future. I’ve already got a dodgey back and shoulder from years of bad lifting!
Old 02-05-2015, 04:09 PM   #1722
katflap's Avatar
A little bit of info.
Top box & large pannier inside measurements w = 38cm, L = 28cm, Depth including lid recess 19cm
Smaller pannier is the same but the depth is reduced to 8cm * for a good 50% of it.
(* I think 8cm is correct struggling to read my own hand writing)
Oil filter
100mm long (metal to metal) with a diameter of 30mm
One end at the centre seems to have a ball bearing and spring style pressure relief valve.
The other end has a glued rubber washer diameter of 25mm, thickness 2mm and hole in the centre of 8 or 9 mm.
Download - circuit diagram including EFI in English
https://mega.co.nz/#!40pADJjZ!1wOenhh9h9QCaSRghWwUlhx_MmcUInDCnSTmBts 4VQE
If your bikes do come with a retracting side stand it’s quite easy to modify if you want to. Im thinking of rigging up a switch and buzzer to let me know when it’s still down!
Old 02-05-2015, 05:20 PM   #1723
Thanks for letting us know. I only read that misinformation in one thread at another website, so I wasn't ready to accept it. You certainly can't believe everything you read on the internet.
Old 02-05-2015, 05:38 PM   #1724
...The front sprocket has 14 teeth with a flange on the inner side. It is secured to the shaft with a bolt and lock washer. The outer side has a hole to one side of the bolt where a small tongue from the lock washer fits in to. The lock washer has a tab that is bent up against one of the bolts flat edges to hold it in place. Im sure you know the sort of thing it is.
Sorry I can’t give you shaft and spline details at the moment but I want to make sure I can get a replacement lock washer before I start taking it a part...
Thanks for checking, and posting the information. If you counted 14 teeth, I'm sure you are correct. It's nice to know a 13T, counter shaft sprocket is available on Taobao. I'm sure I will want to gear down the sprocket ratio to accommodate the 17-inch rear wheel on the CSC version of the RX3.
Old 02-06-2015, 04:33 AM   #1725
Oil filter
Thanks for taking the time to measure, and post the good information.
