Old 02-02-2015, 05:38 PM   #1651
I plan on keeping the foam, air filter element, and oiling it with BelRay oil.
Old 02-02-2015, 05:39 PM   #1652
After making these minor modifications, I would then submit the bike to Dobeck Performance for development of the EJK controller.
Old 02-02-2015, 05:48 PM   #1653
Incidentally, the RX3 has a nice, large airbox. Notice the spacious, unrestricted tube leading from the air box to the throttle body. Also, the foam air filter appears to be 6.25-inches square.
Old 02-02-2015, 06:06 PM   #1654
I just found this Zongshen decal on Taobao.
http://item.taobao.com/item.htm?spm=...cket=18#detail
Old 02-02-2015, 06:18 PM   #1655
jimjr21   jimjr21 is offline
Without seeing the inside of the muffler it is hard to determine the restriction that it has. The outside shape looks like it would have a single bypass design.
Airbox is a nice large. The opening may be adequate. Will have to put it on the flow bench and test it. Design also looks good to remove water from intake.
I am not a fan of the foam type filters. Too easy to choke the air flow with excess oil.
How thick is the filter? Can find a standard K&N to drop in there if there is enough space.
Currently In the garage in various states of running (or not) order
2015 Rx-3 super speedy blue
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
1952 Ariel Square four
Old 02-02-2015, 06:59 PM   #1656
Yes, I need to receive the RX3 before I can inspect the muffler. If the stock muffler is very restricted, I might consider purchasing an aftermarket muffler. However, the design of the stock muffler looks promising to me.
I apply the minimum amount of filter oil, and I get good results from foam air filters. I don't trust K&N air filters for off road riding. Since it is easier to apply sparingly, I use No-Toil oil on the conical air filters in my Honda CRF250X and Honda XR650L. It does a very good job filtering dust and allows excellent air flow, which is superior to that allowed by conventional filter oils. However, I still prefer using BelRay filter oil for flat foam filters, since it is much easier to squeeze the flat foam and remove the excess oil. Therefore, I prefer BelRay oil for the flat foam filters employed by my Zongshen ZS200GY-2, and the Zongshen RX3.
Judging from the photograph, it appears the RX3 air filter is about 1/2-inch thick.
Old 02-02-2015, 07:32 PM   #1657
Wolftrax   Wolftrax is offline
Wolftrax's Avatar
Mad
Likewise, I don't think the midpipe leading to the muffler has a catalytic converter. Am I wrong?
Please note the nice, large outlet from the muffler. I wish my two Honda mufflers had such large outlets.
It does look like a clean flow from the header through the midpipe. I'm betting the cat is in the muffler right where the midpipe inlet is. Both the CRF250l and TR650 had cats in the muffler just as I described. The Husky was easy to knock out the cats with an air hammer. The Honda is more complicated involving opening the can up and re-welding. That muffler looks like it weighs a ton!!
Mark
2015 Haosen Hawk 250
2014 CRF250L
2014 CB500X Rally Raid
Old 02-02-2015, 07:35 PM   #1658
Wolftrax's Avatar
I hope you do Spud. Dobeck's little black box has been the best and most versatile performance mod I've ever put on a bike.
Mark
2014 CRF250L
Old 02-02-2015, 08:02 PM   #1659
I really like the stainless steel exhaust header. I don't think this exhaust header has a catalytic converter inside it. What do you guys think?
It could. I can't figure out why else there would be a weld bead at that specific point. There is no need for welding during the bending process. Also, it looks like the diameter might change at the bead.
One won't know until a wire is pushed down the pipe.
Old 02-02-2015, 08:06 PM   #1660
I don't see any indications in the midpipe, but the muffler could definitely be hiding a cat. I'd be shocked if there was no cat with this bike, due to emissions regs.
If the cat isn't in the header, I'd be swapping that muffler out. It's probably really heavy anyway.
BTW, the large outlet might be for appearances only. I've certainly seen that before.
Old 02-02-2015, 08:07 PM   #1661
Do you agree with my assessment of the stock muffler? I'm not inclined to spend money on an aftermarket muffler, especially when the stock muffler looks so good.
After inspecting/modifying the stock muffler, I will inspect the air box, and possibly enlarge the intake opening.
Hopefully the stock airbox will meet your needs, perhaps with a simple mod.
Old 02-02-2015, 08:10 PM   #1662
You have my full attention. Did you fabricate a flow bench?
Since you declined to answer my question about your RX-3 motor, perhaps you'll tell me about your flow bench.
Old 02-02-2015, 08:29 PM   #1663
Spud, you may remember this old thread about Pastor Jim's scooter, where I found a cat in the muffler: http://www.chinariders.net/showthread.php?t=9421
Old 02-02-2015, 08:33 PM   #1664
I missed that.
Not from Tabao.
I have a Superflow SF-60 that will work great.
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
Old 02-02-2015, 09:17 PM   #1665
May I ask where you bought the motor from? Top secret?
Your personal flow bench?
