Old 12-21-2016, 10:30 AM   #151
Never had that problem, even racing in the sand on the Husky in my younger days....or at least I never noticed it....but I was much less "anal" back then. ;-)
This is personal opinion only...(and we all know what those are like) but the only thing I don't like about the o-ring type chains that that they will let in tiny bits between the rubber ring and the chain plate, and the o-rings will eventually break down and leave gaps. If you change a chain "as we should", that's not really an issue though.
Like I stated earlier, the only o-ring chain I've run was when I knew that chain lube would not be in the equation. The O-rings would still allow the chain to move freely. The shiny chain, sprockets and rear rim made for a much sharper looking rear end on the show bike....without all the hassle of constantly wiping. It was a very nice application.
Normal sand is no issue but this super fine sand we have in the spillway just gets in ever thing. On my Honda 200x I was eating up chains like crazy but once I put the o ring chain I had no more problems. It's either get an o ring chain or stay out of the spillway. Yeah right! like I'm not going back there lol. I may just try the non o ring but just dip it in paraffin wax before I go there. That might keep the crud out.
2004 Honda ST 1300
Old 12-21-2016, 11:17 AM   #152
WHOA!! My exhaust is here? I ordered this thing off ebay at 11pm EST 12/19 and it is here 11am on 12/21 all the way from Guangzhou CHINA. Thats not even 2 DAYS!! What in the actual hell is going on right now? At first I thought I lost a few days, or was stuck in the twilight zone until I realized. those silly Chinese have ALREADY cloned the Star Trek teleporter! Those guys can clone anything!! The GIGANORMOUS Amazon facility is only 20 minutes from my house and I don't even get stuff from there THAT fast. Craziness! BUT I LIKE IT!!
Old 12-21-2016, 11:26 AM   #153
Only one explanation. Flux capacitor. WOW! That is fast
2004 Honda ST 1300
Old 12-21-2016, 11:29 AM   #154
@ 1.21 GIGAWATTS, GREAT SCOTT!!
Old 12-21-2016, 11:30 AM   #155
Ariel Red Hunter's Avatar
Yeah, I was thinking of remarking on parrifin wax treatment of conventional chain, but figured it would be a waste of time. I reccomend UniBear chain because it is not only very high quality, but is a real good bang for the buck. $16.00 is a deal for the difference between what came on the bike and Uni-Bear chain and is, to me, a bargain. On hawk Talk I wrote a whole ariticle on how to wax treat a chain. Sincerely, ARH
Old 12-21-2016, 11:38 AM   #156
New Dilithium Crystals, perhaps?????
Old 12-21-2016, 01:59 PM   #157
Azhule   Azhule is offline
Found themselves a key to the TARDIS ?
Old 12-21-2016, 04:02 PM   #158
I'm gonna have to order some more stuff from them. Lemme go see what else they have!!
Old 12-21-2016, 08:23 PM   #159
hertz9753's Avatar
I think I said some thing similar because it really does ship from China. The reason I looked for and bought that exhaust is because it is aluminum and will bend if you need it to. The other exhaust systems that people posted were stainless steel. They wouldn't bend or save as much weight.
Old 12-21-2016, 08:27 PM   #160
Yep. chuck nailed it.
Here's a pic of the box and the chain. This is the 530 "gold" chain (not sure why) for my Rhino. Note the "solid rollers and bushes" emboldened on the box.
Some chains have been made of rolled steel sheet, and sheet bronze to make bushings. This is faster (and cheaper) than buying drawn steel for the rollers, and the same for drawn bronze tubing for the bushings. There are many ways to make a chain cheaper than someone else does. This the famous "Just as good as" sales pitch that has been around for most of our lives. Luckily I bought into that fairy tale only once. Sincerly, ARH
Old 12-22-2016, 07:14 PM   #161
In case anyone was wondering the factory chain length for a Brozz with a 17 tooth front and 46 rear is 128 links. New chain on the way.
Old 01-02-2017, 02:34 PM   #162
BigWeld   BigWeld is offline
BigWeld's Avatar
This thread is choke FULL of great info! The only downside, is the shopping list keeps getting longer and longer.....
One question: how much does a smaller rear sprocket change the length of the chain? My CB purchase will be used as a commuter 95% of the time, with very little need for a steep 1st gear.
Old 01-02-2017, 03:30 PM   #163
I don't know the exact science to links vs a tooth. When you buy the smaller sprocket just buy a factory length chain, install the new cog, push the rear tire toward the front of its adjustment and bring the chain together to figure out how many links you need to take out. Order a chain breaker along with the sprocket and chain. But I wouldn't put 500 miles on the factory sprockets then put a new chain on them. Chains and sprockets wear together. I'm going to put a new chain on the factory Brozz Sprockets but they only have 80ish miles on them so I think its ok. I'm sure there may be a better way than the way I do it. And others may chime in.
My Stable- 2022 Lifan KPX250 , 2023 Royal Enfield Himalayan, 1992 Honda GL1500 Goldwing, SSR 70 Auto, Kymco Mongoose 90, Honda Four Trax 300
Old 01-02-2017, 03:44 PM   #164
My kind of science
2004 Honda ST 1300
Old 01-02-2017, 03:46 PM   #165
BigWeld's Avatar
My kind of science
I was just thinking in terms of purchasing a new chain to install at initial setup, and putting the factory chain in the scrap bin where it belongs without even using it LOL
