Old 10-23-2016, 01:40 PM   #151
Jmcgee   Jmcgee is offline
Jmcgee's Avatar
Has anyone converted to a cable choke? I think I'm going to attempt it. any experiences may be helpful.
Old 10-23-2016, 02:26 PM   #152
Ariel Red Hunter's Avatar
How long a time do you have to keep the choke on? Bike should be ready to go with no choke, if you start it on choke, then pull on your gloves and put your helmet on. Then push the choke off, and ride.
Old 10-23-2016, 02:47 PM   #153
Jmcgee's Avatar
On the magician it is a little more difficult to get to the choke, It is tucked up in there and on the wrong side of the carb for ease of access, that's why I need a cable. I wish it was as easy as the hawk looks.
Old 10-23-2016, 07:56 PM   #154
Just find something off the shelf somewhere at hd or ace hardware and rig it up
http://www.jackssmallengines.com/jac...z6dhoc5hfw_wcb
You get the idea $6 at agri supply
Old 10-24-2016, 05:48 PM   #155
Jmcgee's Avatar
Thumbs Up
Of course, I know I need a cable with a barrel end, a cable clamp, and a couple brackets, I can look and find or make what I need. just thinking if someone else already did it, it would save time and $ following their steps. My Dad always said a true genius does not just learn from his mistakes, he learns from everyone else's.
Old 10-24-2016, 07:04 PM   #156
95C1500   95C1500 is offline
ILL post a thread about this too but I need an answer. I've got mine torn apart right now (you can read my hawk thread for the reason and all of that) and I need the little gasket that sits inside the centrifugal oil filter cap. I can't find any in eBay, RPS hasn't gotten back to me, and the local dealer that said they HD it, gave me one that was the right shape but was way too big for the cap.so there's two sizes apparently. Is there another engine (one with readily available pars) that would use the same gaskets? Same centrifugal oil filter different engines, etc... Please help, I'm ready to get this thing back on the trails.
Old 10-24-2016, 07:30 PM   #157
The only help I can give you is to repeat what a sales rep told me over the 'phone at APSC. "We carry a Lot of Hawk parts, and what we don't have, we can order in from China". If you want to call them, their phone # is 731-632-3222
Old 10-24-2016, 10:12 PM   #158
Jmcgee's Avatar
My first thought is gasket paper at the auto parts store. I'm not sure what the gasket looks like but http://www.autozone.com/sealants-glu...asket-material they proly got the material
Old 10-25-2016, 01:09 AM   #159
Thumbs Up
Jmcg..spoken like a true Chinese engineer
Old 10-25-2016, 11:15 AM   #160
I can tell you from my quads that the detent must be removed from the choke lever (which is very simple). The choke lever has a barrel slot and hole in it to accept a barrel-end cable. The choke door has a small spring built in that will help the choke fully open, as you slide the lever towards the open position. I think you'd be better off to find a purpose-built choke lever and cable from a quad or dirt bike, rather than a generic item.
Old 10-25-2016, 11:16 AM   #161
To expand your search criteria, I believe that part to be the same as an XR200.
Old 10-29-2016, 05:46 PM   #162
ignition
So, I have been thinking about cdi controlled ignition timing. The only information I have found on the Hawk's cdi says that it has retarded ignition until about 1200 rpm. Then it jumps to maximum advance. I cannot find any information on whether the ignition fires every time the piston reaches the TDC area, or every other time. If it fires on every stroke, that presents a problem. Why? Because if it is, it is firing the mixture that rushed in to the engine when the exhaust pulse created a momentary depression in the cylinder during the valve opening overlap period. And, if it is firing at that time, there will be a pressure wave going not just out the exhaust pipe, but the intake as well. This will disturb cylinder filling, obviously. If we find that it is not firing at tdc of every revolution of the engine, then we only have to concern ourselves with the spark advance. Does anyone out there know the answers to these two questions?
Old 10-29-2016, 07:03 PM   #163
Mudflap   Mudflap is offline
It fires every revolution. What was the other question?
Old 10-29-2016, 07:06 PM   #164
pete   pete is offline
pete's Avatar
If the pick up is on the flywheel it fires every time the piston is at TDC
if the pick up is on the cam it fires every second time...
most bikes infact just about all these days fire a spark every stroke
there is no issue at all with it...
both my Yamaha's & the Honda run a waist spark system...
4 cyclider motors only have 2 coils with 2 leads of each coil..
one coil to 1 & 4 cyclinders.. the other to 2 & 3 cyclinders
so one plug is fireing on the exhaust stroke..
never been a issue in the 50 odd years or more they have been doing it..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 10-29-2016, 07:16 PM   #165
On most of these CG clone engines the spark advance at idle is 15 degrees and tops out at 35 degrees at 3500 RPM.
