Old 05-31-2013, 11:42 AM   #151
Corvairkid   Corvairkid is offline
Corvairkid's Avatar
ive tested every thing i get an input signal all the way from the pick up to the cdi i then get a extremely low voltage out of the cdi to the ignition coil........ 1.2V 2.2V .5V nothing consistent and its same in AC or DC testing
Old 05-31-2013, 11:49 AM   #152
Originally Posted by Corvairkid View Post
yea i checked the Tw book and tested it ageist my stator and got the proper ohms of resistance with in spec 850-1100ohms depending on weather or not I'm cranking the bike or not the TW book didn't give a trigger voltage tho
Measure the resistance values when the engine is cold. You don't make any measurements while cranking the engine. Here are the resistance values from the TW200 and XT225 Service Manuals.
Electrical System Resistance Values
Spark plug cap resistance:
Both Yamaha manuals specifiy 10K Ohms
Ignition coil resistance:
Primary Coil: Yamaha XT225 manual specifies 0.56 to 0.84 Ohms
Secondary Coil: Yamaha XT225 manual specifies 5.68K to 8.52K Ohms
Pickup/Pulse Coil Resistance:
Both Yamaha manuals specify 656 to 984 Ohms
Exciter/Charge Coil Resistance:
Yamaha XT225 Manual specifies 584 to 876 Ohms
I suggest you measure the stator/exciter coil resistance once again while the engine is cold. The resistance value you reported seems a bit high. Also, the pickup coil has been know to fail for the TW200 motorcycles.
Old 05-31-2013, 12:14 PM   #153
Corvairkid's Avatar
ok ill try at lunch and btw spud your right accreditation so over rated
looks like the animal i saw under the cover..... http://translate.googleusercontent.c...1wIK7qEpnToXOQ
good news is it looks like the rotor is the same AC or DC http://translate.googleusercontent.c...8svCEbzjDhRjcQ
Old 05-31-2013, 12:55 PM   #154
Yes, that's the correct stator and pickup coil. I really don't think you are having any problems with your flywheel (rotor).
Old 05-31-2013, 01:52 PM   #155
Corvairkid's Avatar
so i took the plunge (since i got nothing better to do then play with a tinker toy set) and ordered a set of coils and a rotor might as well re place the wiring harness while I'm at it :P jk but this time i know ill have an ac stator ac box AC coil's all AC i will make this bike run if its the last thing that runs over me!
Old 05-31-2013, 04:07 PM   #156
Corvairkid's Avatar
meh it sat a round a long time and god knows what it went thru before hand if i'm going to swap it might as well swap all of it i need to find some torque figures now i think the TW book has some you showed me
Old 05-31-2013, 06:00 PM   #157
If you decide to change the flywheel, you are going to need a flywheel puller and a flywheel holder.
Indeed, I suggest you study the TW200 Service Manual. It explains all the tools needed, the procedure to follow, and the torque specifications for each bolt.
Old 05-31-2013, 06:30 PM   #158
Corvairkid's Avatar
i got the pullers and the holders all ready there main stays for pulling aircraft charging systems
but yea i need to see the book and study it
Old 05-31-2013, 06:47 PM   #159
Corvairkid's Avatar
and fyi a good leather belt and a strong grip makes a good fly wheel holder in a pinch
Old 05-31-2013, 07:53 PM   #160
Corvairkid's Avatar
soooo i come to find my flywheel puller dosnt fit my bike... joy.... any one happen to know what size it is off hand?
Old 05-31-2013, 11:41 PM   #161
Thanks for sharing the good tip.
Old 05-31-2013, 11:41 PM   #162
Yes, read post #45 in the following thread.
http://www.chinariders.net/showthrea...+puller&page=3
Old 06-01-2013, 07:20 AM   #163
Corvairkid's Avatar
thanks spud we need assemble a crash kit book on all this ie build a better zong service manual
Old 06-01-2013, 11:47 AM   #164
Most of your ZS250GS engine is identical to the engine in my ZS200GY-2. Therefore, a lot of the threads in the "Zong Sticky" also apply to your bike, Kid.
http://www.chinariders.net/showthread.php?t=6051
Old 06-01-2013, 01:54 PM   #165
Corvairkid's Avatar
hey good looking out, i was coming to that conclusion but i was a bit slower to the punch i see i was going to start asking about head light wiring since the chump cut the damn plug off the harness.....
