Old 10-30-2012, 11:21 AM   #151
Shows you how much I know about marriage.
Old 10-30-2012, 11:44 AM   #152
cheesy   cheesy is online now
cheesy's Avatar
On my way out to the garage in about an hour. I had a physical this morning and am now filling my face as I wasn't allowed any breakfast. Also walking kind of funny, if you know what I mean. :wink: So, I'm sharing my chair with two small, gassy dogs who would like me to share my brekkie with them. Or grab it and run if they had a chance.
First order of business, though, will be to replace the last fully working light fixture in my garage that I inadvertently smacked with scrap lumber last night, while hauling said lumber to my fire pit, sending said light fixture to the floor and plunging said garage into total darkness. If swearing was light last night, I'd have been wearing shades. Wish I hadn't been wearing my sneakers, either.
Probably will be finding bits of florescent bulbs for the next month.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 10-30-2012, 12:05 PM   #153
You never cease to crack me up Cheesy.
I send a few guys home every daya walking a bit off..... :roll:
You don't even want to know about the girls! :roll:
Old 10-30-2012, 09:30 PM   #154
cheesy's Avatar
There was progress today. I was going to do a step by step pictorial but the battery was dead on the Iceland camera and my phone wouldn't stop ringing. Anyway, at this point I had a charged battery and got a pic of all the paraphernalia cleared away and getting ready to drop the engine.
One last step, pull the fan shroud. Gotta say, the fan looks in real nice shape.
Okay, the gurus at the cx500 forum say an engine drop should take 2 hours or so for the first time. Well, four hours later, here we are.
Heavy little bugger, 160+lbs. This is where I stopped for the day. Gotta scrounge two more 4 x 4s to get it up to a comfortable working height. Confidence is high that I caught the cam chain in time, no sparklies in the oil. The tiny coolant leak I couldn't find is found, it is either around the temp sensor or the sensor itself.
More pics tomorrow when I open up.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 10-30-2012, 10:47 PM   #155
Thanks for posting the photos and the update, Cheesy. Did the engine have any support beneath it? It appears all the engine mounting bolts were located high. :?
Old 10-30-2012, 11:20 PM   #156
Big Job.
I'd say 4 hours was very good time. Putting it back together of course is the trick... :wink:
Old 10-30-2012, 11:35 PM   #157
cheesy's Avatar
No support below, Spud, engine is a stressed member. Made it easier to get the jack under there. Water cooling sure makes it a PITA, though. Last MC engine I pulled was a CB750 and I think that was less than 2 hours.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 10-31-2012, 12:08 AM   #158
I'll certainly be following your progress.
Is it just me, or would that engine make a perfect mini hot rod engine?
I need to book an appointment, so I can walk funny for awhile. I'm overdue.
Old 10-31-2012, 07:57 PM   #159
cheesy's Avatar
Well, what I found wasn't unexpected but that didn't make it any easier when I found it. But, I promised a more or less Step by Step, so here goes.
Pulling the fan. This has nothing to do with the cam chain issue but I'm going to an e-fan and I was curious about the condition of the fan. Turns out the fan was perfect.
The rear engine cover. Under here is where the problem lies.
Pulling the water pump. This to was in pristine condition.
The nice shape of the fan and water pump was building up my hopes. Alas, they were dashed as I found that the cam chain guide and tensioner were only half there. The rest of the guide and tensioner were laying in the bottom of the engine.
Once the flywheel/rotor was off, I could get a better look at the damage. There was some munching going on between the the chain and the block. Guess I'll be pulling the front cover and cleaning out the sump.
Here is what I pulled out.
And here is what the parts should look like.
Back together with a new chain and valves timed.
Going to walk away from it for a few days and get back to finishing the spare room.
Stay tuned for the Mechanical Seal.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 10-31-2012, 08:28 PM   #160
Wow, that looks way familiar... Pretty much the same shape mine was in. Mine was really low mileage as well, I was shocked at the damage.
Old 10-31-2012, 10:38 PM   #161
Egads! 8O
I've never seen a cam chain tensioner disintegrate like that! :?
Old 10-31-2012, 11:04 PM   #162
cheesy's Avatar
I think the tensioner went first and took out the guide. I've done a bit of looking around and found out that there is a beefier tensioner available so I'm going to hold off on buttoning up the engine until I get that one.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 11-03-2012, 07:18 PM   #163
cheesy's Avatar
Finally, finished that freakin' room today. :evil: Not a square corner or straight wall anywhere. :evil: :evil: I despise home remodeling.:evil: :evil: :evil:
Back to the engine tomorrow. As I'm waiting for a new and beefier tensioner, I'll probably pop open the front cover and inspect the sump and the clutch and see if I can find anymore of the tensioner and guide. Probably make some new cover gaskets, double check the stator, and start planning the the e-fan conversion.
Then off to FL for a week of railroad equipment repair insanity. :?
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 11-04-2012, 08:38 PM   #164
cheesy's Avatar
Youngest daughter called and asked if Mrs. C and I would like to meet for lunch today. So, being the award winning Dad that I am, I didn't get much done today. It was worth it just watching her trying to get close to table with the brewing grandson inside her having other ideas. Award. Winning. Dad. :wink:
I did manage to bench test the stator. Perfect. (whew)
Knocked out the water pump seals. Old on the left, new on the right.
Installed the ceramic seal into the impeller.
That was as far I got with the pump seal. Need to do a mix of cooling and heating parts to get the seal into the cover. Seal is in the freezer. Somehow, I can't see Mrs. C letting me heat the cover in the oven so it may be time to punt on that for the time being.
Also made a new rear cover gasket using 1/32" Fel-Pro Karrepack gasket paper, a few bolts and my trusty 5oz ball peen hammer.
That's all until next weekend.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 11-04-2012, 09:19 PM   #165
Good work! You got a lot done. Clever gasketmaking. I have read about that technique but never done it myself.
