03-31-2021, 06:17 PM | #136 |
Oil Cooler...
Hi Jerry,
You know I wasn't too sure, so I thought I'd ask you just to be sure... Thanks again... Ride safe... Joe... |
04-02-2021, 11:11 AM | #137 |
The "RIGHT" carb for the Venom X22R???
Hi Jerry,
I saw your response about the carbs (on the Venom X22R) and was wondering about something? Ok, so IF I order a carb for the Venom X22R, which carb (the PE30 OR the PWK30) should I get??? Also, what is the front AND the rear sprockets that you're running on the Venom AND can you provide a link??? Thanks... Take care of yourself... Joe... |
04-05-2021, 09:22 AM | #138 | |
04-08-2021, 10:47 AM | #139 |
MY VENOM X22R MOD’s
Hi Jerry,
These are the mod’s that I'm planning on doing to my Venom X22R, when it comes in. I am not mechanically inclined so I am limiting the mod’s I do to something I think I can handle (hopefully) without too many problems. 1. Replace the mirrors with the same ones you have. 2. I plan to gut the cat out of the exhaust pipe and also remove (or grind out) any obstructions in the pipe. 3. Install the same headlamps and running lamps you have. 4. Install accessory running lights (spotlights) somewhere on the front forks (for better night time riding). 5. Install an air horn (or at least something louder – AND safer). 6. Install a higher tooth front sprocket (for a higher top end at lower RPM’s ). 7. Install a higher tooth rear sprocket (for a higher top end at lower RPM’s). 8. Install new front turn signal lights and running (brighter lights). 9. Install an air pod on the carb intake and possibly get rid of the air box (maybe). 10. Install an oil cooler system (like yours). Now here is where I start running into your needed suggestions. I do not plan on doing ANY engine mod’s (other than a NEW carb replacement - if needed). I feel this is something beyond my knowledge and expertise. I'm unsure of which carb to get, seeing that I’m not doing any significant engine mod’s (unlike you) or even if I need to get a new one. Like you, I am building a bike for the long haul and NOT for top speed. I plan on riding mostly on the back roads 70-90% of the time with the remainder being highway time… Right now ANY suggestions (or even recommendations) concerning the carb (OR anything else) would be appreciated. Thanks Jerry for your help… Joe... |
04-08-2021, 11:05 AM | #140 | |
04-08-2021, 01:16 PM | #141 |
Jerry, where did you buy the jets and sprocket for the ghost?
04-08-2021, 01:23 PM | #142 |
From Amazon.
Sprocket https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Jets https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
05-15-2021, 03:01 PM | #143 |
Best way to remove decals on the tank???
Hi Jerry,
I'm currently waiting for my bike to be shipped to me (since the 25th) and was wondering what is the best way to remove the decals on the tank (without damaging it)??? Any suggestions on how to do this??? Thanks and stay safe... Joe... |
05-15-2021, 11:44 PM | #144 |
I would imagine goo-gone will make that job easier. I dont think any of the decals are clearcoated on the bike.
05-16-2021, 08:26 AM | #145 |
All the warning labels can be removed easily but all the graphic decals are clear coated.
05-16-2021, 11:17 AM | #146 |
New guy here. Might be ordering an x22r Monday.
Enjoyed reading the thread and if this is in the wrong place to ask I apologize in advance. If porting the heads, removing two layers of head gasket, grinding out welds in exhaust pipe, removing cat and enlargening the connection pipe to exhaust I’m curious if they following would be correct: Oil cooler 110 jets in factory carb OR different carb altogether? Ngk spark plug you list in your signature Anything else? Is the advance key only useful with cam change ? |
05-17-2021, 07:42 AM | #147 | |
05-17-2021, 09:43 AM | #148 | |
05-17-2021, 06:55 PM | #149 | |
My question is; might you know where I can get a clutch pack for the x22r? Venom/Belmonte said they couldn't get it. and redfox is no longer in business. I'm all kinds of lost with no end in sight. The only option I'm finding is replace the entire engine from alibaba for roughly 600$ (350$+ shipping) thanks in advance |
05-18-2021, 08:15 AM | #150 | |
