Old 03-25-2017, 10:32 PM   #136
Ariel Red Hunter's Avatar
Originally Posted by goat67 View Post
I figured out what to do with all the lines except the crankcase breather line, I think I can just let this one purge out instead of going to the air box.
I would put a PCV valve in that crank case breather line to reduce crank case pumping losses, and to keep dusty air or water from being sucked back into the crank case....ARH
Old 03-27-2017, 12:57 AM   #137
ughmas   ughmas is offline
ughmas's Avatar
Originally Posted by manny View Post
I did Merlin, and I'm sorry you had that experience!! Truly sorry!! I'm just blown away that they get away with it and stay in business.
The whole thing has got me a little bummed...I was excited about getting a new toy...Even cancelled my trip to sunny Florida to buy one, and now I have nothing...no sun tan and no bike...but at least I still have my money I guess.
And I have made a living taking risks, big risks, but buying one of these things truly scares me, and that's just not right. I should not be scared to buy a brand new motorcycle, but you guys are right....when we buy one of these things, we are basically acting as a wholesaler and taking on all those risks....and when you look at it like that, it's a lot less of a deal.
I've just been looking at used bikes again, and that's depressing too
Slightly off topic, but just noticed you are in Binghamton! I live in Endicott and work in bing, small world. Let me know if you get a bike and want to go for a ride. If you are considering a TT250 at all you can check mine out!
2005 CBR600RR
2016 CSC TT250 Coming Soon
Old 03-27-2017, 08:02 AM   #138
manny   manny is offline
Awesome, and yes it sure is a small world sometimes!!
You know, I keep hearing people mention theTT250 but I have not seen one advertised anywhere yet and don't know anything about them yet.
Old 03-27-2017, 08:36 AM   #139
Merlin   Merlin is offline
Question
Hey, I saw the new model Brozz coming out, and it's water cooled!
Could you post a link?
Bashan Blaze
Old 03-27-2017, 09:26 AM   #140
https://www.alibaba.com/product-deta...838.0.0.N4aNnV
IDK if it will be available in the US anytime soon, but here's what I saw...
Old 03-27-2017, 09:40 AM   #141
Thanks
Bashan Blaze
Old 03-27-2017, 11:42 AM   #142
I run nothing on any of my crank vents (like all my older bikes came from the factory) and have for years without mishap....but you'll get slaughtered here for that. If you don't want to go the PCV valve route, you can simply also run a proper fitting plastic fuel filter off the crank vent hose to keep the hooligans out.
If your airbox is like the TT250, it's also the inner rear fender and hangs the start solenoid off the left side.
I cut up a plastic office trash can (known as "trash can mod") I picked up from Lowes for about 5.00, then zip tied it in place, along with the side plate I made to hang the solenoid or any other items down the road. The Nibbi filter will barely clear the frame but it fits.
Old 03-27-2017, 03:36 PM   #143
MOTOXtreme   MOTOXtreme is offline
Has anyone confirmed the size chain for the Brozz yet? 428x130 ??
Brian
Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com
"Imagination is more important that knowledge" Albert Einstein
Old 03-27-2017, 04:00 PM   #144
BigWeld   BigWeld is offline
BigWeld's Avatar
Not yet, my Brozz shows up tomorrow, and I haven't even ordered a replacement yet because I don't know the specs.
Old 03-27-2017, 06:46 PM   #145
goat67   goat67 is offline
goat67's Avatar
Can you tell me how to check this?
Old 03-27-2017, 06:49 PM   #146
goat67's Avatar
Thanks I think I will just run it like you did I found the picture in the thread about your wife's bike build.
I have made a bit more progress I will post up some pictures soon
Old 03-27-2017, 09:44 PM   #147
goat67's Avatar
Tonight I worked on fabricating the rear fender and the side shield. I also had to put a notch in the battery box so it was not as close to the rear shock.
Old 03-28-2017, 10:45 AM   #148
Looks great! Excellent job! Depending on where your exhaust runs thru, you may need to trim up the corner of the inner fender somewhat.
I gotta tell ya, the main reasons I did this mod the Mrs. 2LZ TT250 was not just to see how much weight I could save, but mainly to be able to access that rear shock for adjusting. Why they wrapped the airbox around it is beyond me. Keep the pics coming!
Old 03-28-2017, 11:23 AM   #149
dpl096   dpl096 is offline
dpl096's Avatar
Nice post Goat.... Looks like that should accomplish what you needed! Well done
― Thomas Jefferson
Old 03-28-2017, 12:45 PM   #150
https://www.cscmotorcycles.com/CSC-T...tt250-2017.htm
