Old 07-27-2016, 12:58 AM   #136
Jayman77   Jayman77 is offline
Jayman77's Avatar
...of heavy and unneeded stuff.
Hey can I use that trash can
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 07-27-2016, 01:21 AM   #137
Originally Posted by hertz9753 View Post
You must be down to XR250L weight now. Do you have scale you could put the whole bike on?
How would that work? Could you put it on 2 cheap bath scales? And figure it some way?
http://www.walmart.com/ip/Mechanical...Scale/48947430 $6 each
Old 07-27-2016, 01:22 AM   #138
2LZ thats a dramatic pic.
Old 07-27-2016, 01:25 AM   #139
oddthought   oddthought is offline
oddthought's Avatar
Yeah, as long g as you got the whole weight on the two scales, the weights should just add. Analog is best for that sort of weighing since you don't have to worry about timing.
Previous: '80 KZ550, '04 Shadow 750, '12 NC700X
Current: CSC TT250
Old 07-27-2016, 02:27 AM   #140
hertz9753's Avatar
He has been holding out on the trash cans.
My thought is my local landfill or truck stop with a scale that might go that low or maybe a grain elevator.
Old 07-27-2016, 09:57 AM   #141
I think the closest drive up scale to me is at the dump. I know the ol' guy there ok. I wonder if he'd let me weigh the bike? I'd be curious to see if it was really 309 as advertised also.
Old 07-27-2016, 09:59 AM   #142
Hell, ya can't even see all the smog pieces, hoses, clamps and crap in the bottom!
Old 07-27-2016, 01:34 PM   #143
kohburn   kohburn is offline
kohburn's Avatar
most of those drive on scales are not accurate at low weights
if you only have one bathroom scale you can to one end at a time with a block under the same height as the scale under the other end. then add them together.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 07-27-2016, 01:40 PM   #144
SeerAtlas   SeerAtlas is offline
scrap metal recycler will have an accurate scale for under 500lbs.....
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking
Old 07-27-2016, 02:11 PM   #145
motopat   motopat is offline
Originally Posted by darmst6829 View Post
I looked today and found that I have a 17 50 combo as standard and the motorcycle will do 50mph tops. A cruise speed of 50 would be OK with WOT of 60 would be better. Possible?
I don't get it. I have the same bike, your in Redmond and I'm 90 miles away near Olympia. Yesterday I reached an indicated 70mph. It took awhile on a long and flat road and maybe my speedo is a little hasty, but wow, our top speeds are quite different. I have about 450km on the bike and weigh about 185. I also had my sportbike saddle bags on. All I've done is change the oil and check the valves (they were within spec).
Old 07-27-2016, 02:51 PM   #146
mtiberio   mtiberio is offline
mtiberio's Avatar
did you weigh what you put back on? like a different air filter and muffler?
Old 07-27-2016, 03:05 PM   #147
Scroll down, post 103.
http://www.chinariders.net/showthrea...t=17091&page=7
Old 07-27-2016, 05:43 PM   #148
kohburn's Avatar
you hit 70? gps confirmed?
I hit 67 today in full tuck running the 43t rear sprocket at about 7700 rpm.
- 2016 CSC TT250
Old 07-27-2016, 05:58 PM   #149
Jayman77's Avatar
65 full tuck as well I am over 200 lb now maybe if I lose 40 lb I can EASILY hit 70 or 73
I do not expect to do 70 on this without serious modification
However it is rode 3x more that my shadow
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 07-27-2016, 06:13 PM   #150
Azhule   Azhule is offline
Now, just imagine if you lose 80lbs (I wouldn't recommend it, as I'm 40lbs under weight according to the Drs.) and then slap a 39t rear on that puppy ... I'm only 5.4 mph away and then I can travel back in time if I custom fit the bike with a "Mr Fusion Juicer" , and yes this speed is 'GPS verified' (on a calm/slightly windy day)... it was showing '83 mph' on the Garmin (or was it the TomTom?) according to the Mrs. ... and I was 'full tuck' also
