Old 02-10-2016, 03:52 PM   #136
DaytonaMike   DaytonaMike is offline
DaytonaMike's Avatar
Yes, thats a great idea. I tried it with the right mirror but all I had was some cheap silicone and it yellowed very quickly and looked terrible. I will look to see if I can find some higher quality stuff.
Originally Posted by rjmorel View Post
Mike can you just put some clear silicon seal around the perimeter of the glass to hold it in as a safety backup for when it loosens again. Then when it's loosened on it's own , if it does, it would be easier to pull out and save you from some drama of trying to get it out the hard way ? rj
Old 02-24-2016, 02:08 PM   #137
adriansk8   adriansk8 is offline
Send a message via Skype™ to adriansk8
Good Afternoon,
lately I is consuming a lot of fuel, and I have installed the new carburetor that are changing by warranty, TK carburetor, but still giving me a yield of 70-75 km/g.
Some of you who are on their bikes consumption?
I can configure as well the carburetor to better fuel efficiency?
Old 02-24-2016, 04:38 PM   #138
olegeezer   olegeezer is offline
Akt250tt
I recently purchased the 250TT in Medellin and began a tour headed south. I developed a fast idling issue and so I took the bike in to a dealer in Santa Rosa.
They performed the first warranty service and tried to address the fast idle issue (4000 rpm when stopped and the clutch is disengaged). In the same day I took the bike to 3 different dealers (two more in Pereira) and the last one adjusted the carb and apparently solved the problem. I have only put about 40km on it since the last adjustment so tomorrow I will know more. Otherwise I am very satisfied with the bike but I only have 700km on the clock.
I still haven't got a good measurement of fuel economy.
Old 02-27-2016, 07:59 AM   #139
Carburetor replacement
The fast idle issue persists and I am now in Popayan, Columbia. An english speaking AKT rep has promised me a new and hopefully improved carb by Monday or Tuesday and it will be covered under warranty. More on those results later.
I did get a read on the fuel economy and it appears to be 66mpg. Maybe it will be even better with the new carb?
I's still liking this bike!
Old 02-28-2016, 07:26 AM   #140
Longboarder1968   Longboarder1968 is offline
Battery, carb
It's been a bad week for the RX3, went for service and they found bad gas in the tank, drained tank, replaced filters, adjusted clutch and brakes, changed oil and filters. With the new carb(v-2)w/auto and manual choke, changed earlier, Starting, idling and low to mid level torque improved. Two days later battery died! They replaced the battery, probably with an identical brand and th next morning there was a puddle of battery acid under the bike and acid had splattered over the exhaust, shock, rear brake line. MotoGP(Medellin AKT service center nearby )cleaned up as much as you can 'clean' acid spill, replaced(temporary) battery with used of a better brand and ordered all new parts, including new and hopefully different brand battery, shock, muffler, brake line and bolts affected by acid dump.
Old 02-28-2016, 07:37 AM   #141
Fast idle
Olegeezer, had a similar problem when they changed mine(v1) to the TK carb with Separate auto choke. Carb adjustment AND cable adjustment helped. GL.
Old 02-28-2016, 10:46 AM   #142
New Carb
I am assuming I will get the TK carb too?? Hopefully will know tomorrow.
I need to get back on the tour. The Hotel San Martin is nice but not what I came here for :(
Old 03-02-2016, 04:09 PM   #143
spring(elastic) // Selector Gear
I come to comment that this presented a problem very common with our machines , as I have several friends who have screwed them the spring(elastic) gear selection .
This spare the time AKT do not, and spring(elastic) is a simple , but to make the bike repair is necessary to lower many parts, change oil , lower the coolant , finally it is hard work .
image I'm not sure if it's the part 3 or 15 .
File Type: jpg AjnuHN5fLgRFMz6V24IrY2ADpx2yMOPVojUPlfVNVPs0.jpg (44.9 KB, 426 views)
Old 03-02-2016, 08:32 PM   #144
I read a report of spring #3 failing at the following thread.
http://www.mychinamoto.com/forums/sh...-report/page11
Old 03-15-2016, 03:05 PM   #145
Carb replacement
I had the new carb replaced under warranty in Popayan, Columbia. No cost other than my time and hotel charges waiting for the work to be done. The carb is performing well. I do not know which carb I got? I saw the carb and the box it came in but there was no labeling that I could find?
I have ridden the bike approximately 2600km so far and I am in Banos, Ecuador.
I have about 3 or 4 weeks before I go home and I am searching for a place near Quito to leave the bike and come back to it within a year.
The only other problem I've had is my auxiliary lights quit working. I have not had the chance to trouble shoot this issue but I will soon. If anyone has had this happen please advise. It should not be too complicated but I always think that in the beginning......
Old 03-16-2016, 06:22 PM   #146
Olegeezer have you checked on leaving the bike in Ecuador for a year. I thought 6 months was max for "transit" papers.
Old 03-20-2016, 04:20 AM   #147
Leaving the bike in Ecuador
Yes I believe that is correct. (6 months max) Getting the six month extension from Ecuador is also a pain I believe as far as paperwork goes. The current plan is to take the bike back to Columbia and since it was bought and registered there the time won't be restricted. I plan to store the bike in Columbia and return in less than a year to continue the SA tour.
Old 03-20-2016, 07:45 AM   #148
Saw this on a Facebook page from Medellín. Selling for about $30USD.
MEDELLIN
Hola chicos buenos días
Tenemos a la venta para la AKT ADVENTURE
Gato central $91.800
Porta Alforjas $98.800
Estamos ubicados en la cra 52#37-15
Local ABC MOTOS Diagonal a la estación del metro exposiciones.
Bienvenidos por acá ; )
Estamos en medellín pero hacemos envíos a todo Colombia, hablanos al 3008946773
Old 03-23-2016, 10:41 AM   #149
Rodada Occidente Antioqueño
Good morning
Share link on our website rolled the western Antioquia.
regards!
http://clubadventtourmedellin.com/20...te-antioqueno/
Old 03-23-2016, 12:51 PM   #150
Thanks for sharing the link. That looks like a fun ride with a great group of riders.
adventour, akt tt, akt tt 250, colombia
