Old 05-16-2016, 03:47 PM   #136
muzo_31   muzo_31 is offline
No doubt about the conclusion.
I don't have much information, but it sounds like my Quadro has a new generation O2 sensor. From a previous model, it has a much compact form factor, but similarly to your model, it only delivers a small volt, no more.
Old 05-24-2016, 12:12 PM   #137
katflap   katflap is offline
katflap's Avatar
PCHUD remote desktop
I'am wanting to do some live monitoring whilst riding. Here's a solution
mirror laptop desktop to android phone via bluetooth.
http://www.pcperegrinato.com/
This is a free solution, some of the pay for apps have a better frame rate but this is ok for me .
Once connected and setup its laptop in the topbox and phone strapped to the handlebars
Name:  hud remote desktop.jpg
Old 07-18-2016, 01:14 PM   #138
katflap's Avatar
Updated link,
This is an all in one download that includes
PCHUD with instructions
"Clear fault codes" software with instructions
A guide to making your own data connection using a vag com cable
and other info
https://mega.nz/#!J0ZAHQaT!gAEUp0fpN...S0DxDBrjmzccV4
Old 08-31-2016, 03:23 PM   #139
katflap's Avatar
Clever chap "zlobniyslaine" has made an android app that will conect to the Delphi MT 05 via an elm 327 bluetooth interface
At present, It will show and log data . Once he has fully tested it he plans on adding a dashboard with gauges and eventually put it on to google play.
I plan on testing it once my cheapo elm bluetooth is delivered.
here is a link to the app as it is so far.
http://zlobniyslaine.org/files/gt650rc.apk
More info here
http://korider.com/index.php?topic=27907.0
Old 08-31-2016, 03:54 PM   #140
So cool! I have a wifi-based OBDII reader for my pickup, but when my phone is connected, it presumes that data is no longer needed. I'm going to switch to a Bluetooth unit.
Old 08-31-2016, 04:55 PM   #141
i figured this would come a while back. there are millions of people all over the world figuring out stuff for the rest of us.
Old 09-01-2016, 10:52 AM   #142
It turns out that iOS-based OBDII readers are much harder to come by than ELM327 stuff for the Android folks. I bought this one and I hope it does the trick: http://www.ebay.com/itm/391517651622
Old 10-31-2016, 04:34 PM   #143
Edalsaadio   Edalsaadio is offline
Good, someone could share the link to download the program since that hung already expired. Thank you.
Old 11-01-2016, 02:09 PM   #144
katflap's Avatar
I'm guessing you want the PCHUD software ?
See post #1 for an updated link
http://www.chinariders.net/showpost....74&postcount=1
Old 01-28-2017, 12:39 PM   #145
katflap's Avatar
More info here
I've had a good play with this app now, but I just can't get it to work.
I've tried decompiling it , adding and taking away bits, but still no joy, my knowledge of android just isn't good enough
It did give me some tips and have been able to communicate with the Delphi ECU by using an elm terminal app.
By inputting -
ATZ
ATSP5
81
2101
you get a reply ,which is a string of bytes, similar to the list zlobniyslaine posted.
I think that these bytes represent the PIDs that are available
The android app Hobdrive, I have tried . This app is very configurable but you have to do it manually.
With some adjustments I have managed to connect and get some readings but because its either picking up the wrong PIDs or the wrong conversion is being applied, the figures shown make no sense.
Some how I need to identify which sensor is providing which set of figures.
I have little knowledge of this stuff so it could take awhile if ever
Old 01-26-2018, 03:10 AM   #146
mogeman   mogeman is offline
Hi guys,
This is a great thread but I unable to any data for the MT05 (my MT05 is for 2 cylinders with 2 oxygen sensors).
I run the PCHUD (MT05EN.HUD) on winXP which is I believe show only for single cylinder data.I used ELM327(CHY340) ,double checked the pin connectors accordingly and com port.
Any enlightments much appreciated,Thanks
Old 03-29-2018, 05:19 PM   #147
250utv   250utv is offline
I have downloaded the PCHUB software to my 32 bit computer, and gotten the correct line to connect the Delphi ECU diagnostic plug to USB, but my computer doesnt see the ECU when I turn the ignition on. Also, with the downloaded PDHUB software, it is all in either HUB or PAR file format. I am unable to open them up to view it. I am new to all of this and could really use some help. I have gotten the software from BitBox as well, and after spending close to $350, still not able to open the ECU to read write new fuel curves. I can't even open it up to see the log screen. Any help with this would be great. Thanks
Old 05-12-2018, 01:37 PM   #148
azif   azif is offline
Download PCHUD
Hi guys, my name is Sebastian Pinilla, from Argentina. I try to download PCHUD for MT05 but the link doesn`t work. Anybody can help me?
Thanks!
Old 05-12-2018, 06:10 PM   #149
send me a message, I have the pchud software available for you
Old 05-12-2018, 06:14 PM   #150
update: I have kind of given up hope on opening the pchud software and gotten the software from bitbox to work pretty good. I can read, write and edit the program now. I have been playing with all sorts of settings and I enjoy it. And it works on 64 bit computer running windows 10! I still have the pchud software, but i'm not able to open the PAR or HUB files.
So, without being a computer geek, the bitbox stuff is easy to use big time. I made my own adapter and it works just great. I had to get the reader from another source, but it was not to bad in price.
