#136 |
Not surprised. It seemed too good to be true at that price.
#137 | |
![]() By angle, are you saying that the upper suspension link is bent? Does the forward / reverse box use a cable or lever?
#138 |
I have not confirmed what is out of alignment. It has been this way since it arrived.
The reverse box uses a cable. I think it is stretched as I have the adjustment maxed out. Yesterday the battery started it right up, but the little display is not working. Seller said they would replace it. Just need to ship it back.
#139 | |
#140 |
I still have the old battery. It can go back in while I wait for a replacement.
#141 | |
Good news that they'll replace the battery. Are they paying shipping?
#142 |
They are sending a return label for the battery. I just have to fill out the form.
The cable attached to a lever that defaults into the reverse position. The lever is spring loaded. The cable adjustment is maxed out and still does not pull it all the way into forward.
#143 |
Is the cable stretched too far? I've had that happen with parking brake cables.
#144 |
I think a new cable is the fix. Seems that it is stretched too much to keep it in forward.
#145 |
Can you shorten the cable, hillbilly style? I once had a Mercury Sable with a brake cable stretched beyond what could be adjusted. I loosened the cable as far as it would go, which had it laying on the ground. I put a small loop in the cable, secured it with a small cable clamp and loctite, adjusted the cable and called it a win.
Maybe you could shorten the cable with a knot or two.
#146 |
I am thinking so since the cable works otherwise.
#147 |
I crimped a lock washer around the end of the cable and it works fine again.
#148 |
That's creative; hadn't thought of that.
#149 |
Recycled from leftovers.
#150 |
Didn't take any pictures, but we got some time riding in the snow and pulling sleds. Yard is covered with about 2 inches of snow.
