Old 06-01-2016, 01:49 PM   #136
katflap   katflap is offline
katflap's Avatar
Some of my parts arrived to today
1/ revotec (SST8K) self sealing 8mm barb -
My gut feeling is that the internal diameter of 5mm might be too small to gain the full benefit.
Now seeing it close to the bottom hose, I don't think it will squeeze the hose flat as much as i Initially thought, when fitted.
2/ Koso 18mm water temp sensor adapter-
This comes with a water temp sensor, the adapter sensor hole is 1/8 NPT.
My inital plan was to fit the gauge temp sensor in to this adapter. spud measured our gauge temp sensor as M10 with the fine 1.0 thread.
If this is bigger than 1/8 NPT then a larger tapped hole will be need. The boss on the adapter is only 13mm wide so quite tight.
Our temp sensor will require a ground wire attached to the adapter.
I plan on using an after market temp gauge that comes with a 1/8 NPT sensor.
To use the koso adapter as the bottom hose connector would be very tight if not impossible (see picture)
Name:  connectors on hose.jpg
Old 06-05-2016, 08:45 AM   #137
katflap's Avatar
Got my temp gauge fitted today so I can now easily monitor the coolant temp and get some temp readings before and after fitting the by-pass.
Did a quick test, ran the bike stationary until the fans kicked in (81c) then set off.
Average temp whilst riding 60c with an air temp of 22c.
Name:  Temp Gauge.jpg
Name:  Temp Sensor.jpg
Old 06-05-2016, 09:08 AM   #138
detours   detours is offline
detours's Avatar
Very cool, Kat! Looking forward to the after test and pics of the fittings.
How long did it take to warm up to 81 C, when the fans kicked on?
Red 5 standing by!
2014 Ural Patrol
Old 06-05-2016, 09:37 AM   #139
dpl096   dpl096 is offline
dpl096's Avatar
Sweet! I'm old school too and prefer actual readout gauges over idiot lights. My preference is still old style needle gauges but I reckon these here new-fangled digital gauges might be acceptable . I'm also looking forward to your findings.
― Thomas Jefferson
Old 06-05-2016, 09:55 AM   #140
Juanro   Juanro is offline
Juanro's Avatar
I must be missing something. If the average temp of the cooling liquid was 60C, that means that the thermostat isn't opening? (Thermostat was 70C?)
Old 06-05-2016, 10:31 AM   #141
katflap's Avatar
Thanks detours, I didn't think to time it but I think it was around 15mins but I was doing other things whilst it was warming. Also I did rev the engine a bit at one point to speed the warming
Old 06-05-2016, 10:35 AM   #142
katflap's Avatar
I love a good old needle gauge too, but they seem to be quite pricey or at least the ones that gave you a decent temp scale.
Hope to fit the by-pass soon
Old 06-05-2016, 10:42 AM   #143
katflap's Avatar
No your not missing anything
This Is a bit of an oddity that I hope to discover what is going on.Unfortunately I didn't have time to test my thermostat In a pan of water to see If it is Faulty.
If it turns out not to be faulty, the idea of the by-pass and then eventually a higher rated thermostat should raise the coolant running temperature
Old 06-05-2016, 04:10 PM   #144
I suspect that the thermostat is opening until it gets a slug of cold water, then closes. The hot water that passes through the thermostat gets cooled by a radiator so when it gets to the temp sensor the water has lost some 20 degrees of heat. This is the same hot/cold cycle KLRs had to deal with, thus the thremobob bypass system.
Old 06-05-2016, 04:47 PM   #145
Juanro's Avatar
I see the temp sensor just after the motor output.. this should be the hottest point, and it's -before- the thermostat.
Old 06-05-2016, 05:05 PM   #146
Juanro, in the stock arrangement you are correct. I was talking about Katflap's meter, which is taking information from a sensor he mounted in one of the radiator hoses. Thus, he's getting the temp after it has passed through the radiator. Katflap found that that temp was only 60C even though the thermostat was supposed to open at 80C.
Old 06-05-2016, 07:04 PM   #147
Juanro's Avatar
Yes, I'm looking at the picture he posted... the temp is mounted using the Koso adapter in the hose at the -output- of the motor, even before the stock mounting of the thermostat. I expected to see higher temperatures there.
Old 06-05-2016, 08:43 PM   #148
Oh, looking at the photo I thought the sensor was after the right radiator. I guess I need to take a closer look at my own bike.
Old 06-06-2016, 10:35 AM   #149
katflap's Avatar
Juanro is right about where I position the temp sensor but my photo doesn't show it clearly this one below is better.
I noticed on my ride to work this morning the temp rising from cold quite rapidly then It reached 52c followed by a marked jump to a few degrees less, typically indicating a thermostat starting to open, way too early !
I really need to test my thermostat out of the bike before I go any further with fitting the by-pass. Fortunately I have a new one coming from China soonish , I will check the new one as well.
Name:  koso temp sensor & connector.jpg
Old 06-06-2016, 11:02 AM   #150
Watt-man   Watt-man is offline
Watt-man's Avatar
Kat, here is a testing tip: put the 'stats in your test pot of water with the rubber down and the wax housing (the part that says "70C" on it) aimed up so you can see it. Before heating, carefully notice where the wax housing is relative to the surrounding spring support. The operating temperature is that which moves that wax housing only 1 mm. Lots of people would think that it has to move 3mm or so to be "at operating temperature" but that is not the case.
Watt-man
2004 KLR650, 137,000 miles - never torn down yet.
www.watt-man.com
