03-07-2017, 02:36 PM | #136 |
If it doesn't maybe Ski could take some pictures and measurement of the wheel assembly to see if it is the same as the Hawk.
03-07-2017, 02:37 PM | #137 |
From APSCUSA's page it's analog with a gear position indicator and i'll bet money the odometer is in Klicks.....
03-07-2017, 02:42 PM | #138 |
Hopefully it is in MPH and more accurate than the Hawk Cluster was.
03-07-2017, 02:44 PM | #139 |
Reason i think it's in Klicks is the Kilometers are white BIG numbers and the MPH is yellow SMALL numbers. Big numbers on the speed usually coincide with the odometer as well......
03-07-2017, 02:48 PM | #140 |
Yeah I saw that but those pictures look like they were taken at the factory. It may have the corrected MPH speed but the odometer may be in kilometers like the Hawk. Either way maybe you Hawk digital cluster might work on it.
03-07-2017, 03:42 PM | #141 |
Sweet, it has the GENUINE Keihin, which is a good thing. And I already have jets for it. Now I hope it has 17 / 40's gearing.
03-07-2017, 03:54 PM | #142 |
Nice upgrade from the standard garbage PZ's that come on most CB's!
03-07-2017, 04:27 PM | #143 |
I guess I'm one of the lucky ones. I've had no issues with the stock carb.
03-07-2017, 05:03 PM | #144 |
No digital tach. It's the same one that someone pictured above. Probably that same one that comes with the Hawk. At least it's in MPH and not KPH.
Funny thing is that it does come with a remote start key fob... I'd rather the better instrument cluster. |
03-07-2017, 05:15 PM | #145 |
Hope it's calibrated a little better than the one on the Hawk. Mine was almost 10mph off after about 500 miles. Take some pictures and measurements of the speedometer connection before you put the front wheel on and get with mjstef. The Hawk cluster may work.
03-07-2017, 07:19 PM | #146 |
Most of these carbs are all Made in China,even the one on the Enforcer.
03-07-2017, 09:28 PM | #147 |
1 Stock 'upgrade' confirmed! Keihin carb...still waiting for SOMEONE to count the rear sprocket teeth...
03-07-2017, 09:30 PM | #148 |
That would confirm the second 'upgrade'
03-07-2017, 10:11 PM | #150 | |
I had to argue with my manufacturer over the speed thing. They kept telling me all speedos in China read 5-10MPH fast "FOR SAFETY". Finally got them to build my clusters accurate and they are + - 1MPH...... |
