11-16-2018, 08:55 AM | #136 |
Has anyone ever put an actual filter in their oil coolers. I was thinking about this one. Don't know if it would help any.
https://item.taobao.com/item.htm?id=...207:1690965843 |
11-16-2018, 08:58 AM | #137 | |
11-16-2018, 07:31 PM | #138 |
I have the stainless mesh on mine, but the standard one that comes with the kit is just as effective at stopping the bigger particles and takes up less room. I dont have enought hours on it to give a full report on it. Just be aware that the housing is decently bigger than the standard screen and spring.
11-16-2018, 10:47 PM | #139 |
Cool. I wasn't sure if it was any better than the screen that came with it, or worth the money to buy it. One thing is for sure though. I am getting an oil cooler!
Hawk 250 Lithium Battery, Mikuni Carb 110 main jet, Bark Busters with Mirrors, Extended Mixture Screw, 428 O-ring Chain, 17-15/40 sprockets, Digital Cluster, Cycra YZ250F Skid Plate, Oil Cooler |
11-19-2018, 08:27 PM | #140 |
hey guys just surfing the forums and seen this now im totally into doing this mod
so i was wondering is it worth it to have two oil coolers or only one and what cooler should i get ? i was thinking this one ?https://www.aliexpress.com/item/CG12...fbcadc1a06663d
04 flywing 150 05 flywing 150 07 gasgas ec200 18 csc tt250 / foam filter mod, amazon exhaust, mikunki carb, 47tooth sprocket, o ring chain, stereo system, amsoil oil, honda 10w fork oil, tusk bars and brush guards.... more to come |
11-19-2018, 09:32 PM | #141 | |
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-20-2018 at 07:33 AM. |
11-20-2018, 01:35 AM | #142 | |
11-20-2018, 07:50 AM | #143 | |
11-20-2018, 12:48 PM | #144 |
whatd you do to get higher compression?
11-20-2018, 01:30 PM | #145 |
Shaved 1mm off the head.
11-23-2018, 09:33 PM | #146 |
so im about to order the oil cooler i posted a link to but the only thing i want to do first is find a source for extra filters but i cant find those kind anywhere what should i use ?
11-23-2018, 09:40 PM | #147 |
How exactly are you running two? I'm just curious because if I do end up getting one of these enduros, I am obviously going to do the higher compression mod.
11-23-2018, 09:40 PM | #148 |
nvm i just realized i dont need an extra filter right that one is serviceable after re reading the tread i found you guys talking about filters and what i got outta it is the filter on the oil cooler is just a relocated screen filter and its plenty good... what do you do to clean it just spray compressed air threw it when your doing an oil change?
11-24-2018, 08:13 AM | #149 |
I have them connected together in series.
11-25-2018, 11:03 AM | #150 | |
TaoBao Payment
Did you pay direct to them with your credit card? I went through the whole set up process and they confirmed the order. There is a tab to click for payment but it is not a PayPal link but it looks similar to PayPal. When I click it, it immediately asks for my CC info when usually it would direct me to PayPal and then back to the merchant. I don't feel comfortable giving out my info to an offshore merchant. Seems fishy to me. Please advise. I also sent you a PM Last edited by BBOWL10; 11-25-2018 at 11:05 AM. Reason: Addition |
