04-15-2007, 09:28 PM | #1 |
Removing Smog Equipment?
Has anyone removed the smog equipment from their bike. If so, what did you remove and how did you plug the holes? I have a small nipple in the intake manifold and a bigger one the the cylinder head. Does this stuff take any performance away from the engine?
TIA
2013 Jeep Wrangler Sahara MOAB 2005 BMW E53 X5 2011 Schutt Industries LTT-HC LQG trailer 2017 Coleman CT200U 1978 Yamaha SR500E 1979 Yamaha XS650 Special II |
04-15-2007, 10:53 PM | #2 |
I have...I just used a bit of the shipping crate and a bit of grinder work to shape it. I then drilled 2 holes to mount it using the existing bolts and used the existing gasket as well. Not pretty, but works and no leaks
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
04-15-2007, 10:54 PM | #3 |
The vacuum line I just plugged with a screw.
04-16-2007, 01:16 PM | #4 |
This is what I was meaning in my first post. Is there a problem plugging this opening up? I'm just going to cut a small aluminum plate and block it off.
04-16-2007, 01:21 PM | #5 |
Sam,
Akonababe has pics in the gallery of what they did with theirs and how they sealed it...
06 Lifan 200 GY-5 |
04-16-2007, 01:28 PM | #6 |
Thanks, I'll check it out!
04-16-2007, 01:32 PM | #7 |
Yes take a look on page 5 and you will find what we did. If anything it made the bike run better, the plastic hose burns up anyway so you need to get rid of it.
Ride hard and have FUN!!!! |
04-16-2007, 02:22 PM | #8 |
Yes, that's what I planned to do. I can cut a pretty little bracket out of aluminum to bolt right in there. I have some copper sealant that should seal everything up tight.
Thanks!
04-16-2007, 03:17 PM | #9 |
Yep that's the opening I plugged.
