Old 10-28-2009, 03:42 PM   #1
PCD   PCD is offline
Mini Hummer wheels on Mini ATV
I know a few of you have both thse machines.
The mini ATV I'm talking about is the former 50cc that now comes with a 110cc engine.
I would like to put the mini hummer wheels and rubber on the mini atv. Ground clearance is the goal.
Now, i have spoken to GIO and they say sure, its been done before, might have to live with a little rubbing. I can deal with that.
BUT I recently noticed the 2 axles are different (they have some on auction atm)...mini hummer axle is wider, probably to accomodate the larger rubber?
Before I get flogged here...there was a lot going on when I ordered the mini ATV and I also misread the site. Thought the ALL NEW 2010 mini atv really was all new, but its the 50cc with a larger engine.
So....stuff happens as they say...was going to sell it, but I spend a lot of time putting these things together correctly, plus I have perf parts for it....so if I could get a set of decent rubber on it, I can live with it.
Thanks
Good, Fast, or Cheap....Pick Two.
Old 10-28-2009, 04:44 PM   #2
Reveeen   Reveeen is offline
Spend enough time and money and anything becomes possible.
(This from a guy that has 235/85/16's (10 ply) on a Subaru)
Wheel spacers *think* wheel spacers.
Old 10-28-2009, 05:00 PM   #3
TurboT   TurboT is offline
Re: Mini Hummer wheels on Mini ATV
Thanks
Hey Pete,
Are you asking a question here regarding the axles or just musing about things?
I believe the mini hummer and mini beast axles are the same.. I can take pictures of my mini beast axle and one of my 50cc axle if you want to look at them side by side?
Old 10-28-2009, 05:55 PM   #4
PCD   PCD is offline
Thanks
Hey Pete,
Turbo, no, not musing. ready to pull trigger on the wheels and tires.
Hows bout a small fav?
Just eyeball the mini hummers rubber and give me your opinion if it will survive on the little guy.
REVEEN: cant argue with you there. Also wheel spacers is good idea if room allows. Thanks.
Old 10-28-2009, 06:44 PM   #5
And a body lift.
(My ATV is 4 wheel drive with doors, a heater, and air conditioning)
Old 10-28-2009, 06:46 PM   #6
Hey Pete,
I eyeballed AND took pictures. From judging, I expect they'll fit on the back without much trouble, but you may have some clearancing to do on the front.
I do not remember if the diameter of the axles is the same where the wheel bearing rides on the two machines. I don't have time to rip them off and measure for you today. If you want, I can do that for you on the weekend.
Here are the shots so you can see the difference between the two machines.
NOTE: The Mini Hummer in the family is an hour drive away, I have the Mini Beast, but the tires are the same size on both.
This is that ugly frame piece underneath which is a rock magnet..as well as a oil drain plug blocker!! (has to come off to drain the oil)
Old 10-28-2009, 06:50 PM   #7
PCD   PCD is offline
And a body lift.
On the little guy, the body is primarily one piece except for the nose I think. May or may not be easy to lift, but certainly not insurmountable by any stretch.
I will make it work, especially with all your help here.
It was my "mistake" ordering it, and I did make a tenuous gesture to GIO but was rebuffed. Did not pursue it because I didnt have a leg to stand on, so why create bad blood over nothing?
Old 10-28-2009, 06:58 PM   #8
PCD   PCD is offline
TurboT: Wow...thanks a million! Owe you one for sure. You know, the little dude doesnt look half bad in the pic...All this Hot Wheel talk had me really worried about the size of it
I say they will be OK from what I see. Gonna go for it :mrgreen:
Too bad about that frame piece, but what the heck. Its gotta be done to keep the engine alive...looks like a 1 beer job to me
Thanks again man, really appreciate it!!!!
pete
