06-09-2006, 12:43 AM | #1 |
My GY200
I purchased this on Ebay back in December. I had no problems getting it
registered here in N.E. Ohio. I think I have about 50 or so miles on it at this time. Unfortunately the speedometer cable broke with 9.4 miles on it. I have made a few modifications to it in order to make it run better. I'm real pleased with it so far. She runs better and better everyday. I bought some numbers for my kids bikes but they were to big. The smallest they had at the local shop. I decided to add them to my bike just so my money wasn't wasted. Plus my favorite number is 9. I actually bought 3's and 6's for the kids. 6's make good 9's as well. Anyone want some white 3's? PM me. I am adding a link to the bike on TT so you can see some pics. I uploaded some more earlier today. GY200 http://www.thumpertalk.com/forum/gar...hicle&vid=5591 My Profile on TT http://www.thumpertalk.com/forum/member.php?u=81659 I'll try to add any updates as they come along. Happy Riding!
2000 MZ Baghira |
06-09-2006, 04:36 PM | #2 |
I see in your pictures that you installed some handguards. You mentioned that you bought them off of ebay. I want to get some (red or black). I need to get some for my son's 100cc too. He has already broke the brake handle once. :(
1. Were they a generic fit? 2. Or were they for a particular make of bike? If yes, do your remember which bike? 3. Was it a dealer that sold them? If yes, do you have his contact info? Thanks! |
06-09-2006, 07:03 PM | #3 |
dlunt - Yes I did get a set of handgaurds off of
ebay. I don't believe the individual I bought them from was a dealer though. I used to have the link but that computer died a few weeks ago. IIRC I just did a search on ebay for... Universal handguards Mx handguards Enduro handguards Etc... They were listed as universal for 7/8" bars. I thought this was the standard but after I got them I realized that there must be smaller bars, because the bar-end clamps were to small. I had to cut off the ends of the handgrips and throttle tube in order to use them. They didn't fit quite as well as I had hoped. I had to use some rubber inserts I had to keep them in the bars. The clamps for the bars fit fine, but I still had to move the controls around to get them to work. I even loosened and moved the banjo (I think) bolt on the front master cylinder to allow for clearance. Some pics... This is basically the same setup I purchased. http://www.eazys.net/GY200/handguard.jpg I would buy something like this if I did it again. These have aluminum inserts, mine don't. http://www.eazys.net/GY200/handguard1.jpg http://www.eazys.net/GY200/handguard2.jpg This is a pic of the guards from the front. http://www.eazys.net/GY200/front.jpg Pic of the bracket location on the bars. http://www.eazys.net/GY200/saddle.jpg If you look in the pics you can see how the clutch perch hits the one. My levers are out of wack because of them. One high one low. The master cyclinder cover pretty much doesn't cover the whole thing. If you have a local shop I would take the bikes there and hold them up for fitment. I recently saw that the local shop had some that would have worked as well for about $45. This definately was quite the headache project. Knowing my luck they'll break the first time I drop the bike. laughs. Hope this helps...
2000 MZ Baghira |
06-09-2006, 07:53 PM | #4 |
Thanks for the insight and pictures! It is a big help. I was worried that it might be a pain. I will do some shopping and measuring before I buy.
06-29-2006, 05:17 PM | #5 |
Actually got a chance to get out and ride a little today. Kids went to the local pool. 8)
I ran a couple of short errands and decided to hit the trails that I found. It rained quite a bit yesterday and the trails were full of mud puddles (can ya see where this is heading?). Not even tweenty yards into the trail I hit a puddle and found out (again) what it is like to have the front end wash out on me. Bike went straight to the ground on it's left side. I just stood over top of it and thought "Oh, I remember now" LOL. I have done this as a kid but it has been over tweenty years and forgotten what it was like. No damage whatsoever to the bike, just got covered in muddy water. I pinched my index and middle finger between the the clutch lever and the handguard as I laid it down. No biggie. I got right back up and kept on going. I'm definately going to look into some better tires as the stockers are ok for the road but terrible in the mud.
2000 MZ Baghira |
07-01-2006, 12:50 PM | #6 |
Just changed the oil again for the second time last night. Mileage unknown since my speedo cable broke. I figured it couldn't hurt and already had the oil. Here is a pic of the oil screen when I removed it. Bunch of small particles but nothing to cause concern.
http://www.eazys.net/GY200/screen.jpg Also while I was down there I took and cut a bigger hole for the drain plug. I used a jig saw and expanded the original. It works well but only if the bike is in a upright position. As can be seen in the last pic. Next time I'll put a couple pieces of 2x4 under the stand. http://www.eazys.net/GY200/skidplate.jpg http://www.eazys.net/GY200/skidplate2.jpg http://www.eazys.net/GY200/oildrain.jpg
2000 MZ Baghira |
07-12-2006, 11:35 PM | #7 |
Well I went and pulled a stupid the other day. I had an extra plug in the side toolkit on the bike. I decided to switch it with the stock one and take it around the neighborhood for a test ride. Well didn't realize till the following day that I had left the toolkit open and lost the kit and my registration which I had in there. I searched the neighborhood but came up empty. The toolkit doesn't matter but the reg did. I called the BMV and they said I could get a replacement for $4.50. At least it wasn't an expensive stupid. :?
2000 MZ Baghira |
07-12-2006, 11:47 PM | #8 |
Learned a valuable lesson the other day. Was out running around the neighborhood and found out that my gas tank doesn't really have a reserve, just a setting on the petcock. Yes I ran out of gas. Luckily I was only about two blocks away. Just pushed it home and filled it up with a gas can I had at home. I was kinda suprised that I had ran it completely dry without ever changing the petcock to the reserve position. Unless I had it on reserve the whole time? Hard to tell with the markings. The worse part is that my speedo cable broke a long time ago and I have no way to calculate how long I can ride before running out. I do plan on replacing the speedo cable just no funds at the moment.
2000 MZ Baghira |
07-13-2006, 12:04 AM | #9 |
Redid the liscense plate and lights...
Details... http://www.thumpertalk.com/forum/gar...wmod&mid=28472 I replaced the rear turn signals and the mirrors with some from a 2003 Buell XB9. An individual gave and shipped them to me for free. I like them both a lot. Signal Details... http://www.thumpertalk.com/forum/gar...wmod&mid=28473 Mirror Details... http://www.thumpertalk.com/forum/gar...wmod&mid=28650
2000 MZ Baghira |
07-13-2006, 08:01 AM | #10 |
I'm not trying to be a dick here but...you have money to do all these "upgrades" but don't/won't spend money on a "cheap" speedo cable? Besides, shouldn't that be under the warranty?
07-13-2006, 08:42 AM | #11 | ||
Frostbite "The beatings will continue until moral improves" |
07-13-2006, 11:32 AM | #12 | ||
2000 MZ Baghira |
07-17-2006, 03:16 PM | #13 |
A couple more mods I've done in the last few days.
Chain Guard... http://www.thumpertalk.com/forum/gar...wmod&mid=29194 Camera Mount... http://www.thumpertalk.com/forum/gar...wmod&mid=29195 Video Links: Trip to Folks... Trip to Home... Trails I found locally... Not the best quality video, but cool non the less. I need to find someone else locally that rides so I can get out a little more without worrying about being alone. I'm all my kids have. Plus it actually gets boring at times too.
2000 MZ Baghira |
07-17-2006, 06:21 PM | #14 |
Hey Easy, What are you gonna do with ur old blinkers? I'll buy both of the lens(caps) off of ya, one of mine fell off last year.
2004 KAZUMA CHEETAH 200 2001 Yamaha Big Bear 400 1986 Honda ATC 250ES 1983 Honda ATC 200X 1974 Kawasaki KE100 |
07-17-2006, 07:27 PM | #15 | |
2000 MZ Baghira |
