09-04-2008, 12:40 AM | #1 |
Lifan 163FML
What was this clone based off of??
Do we know if it was a old school Honda??? |
09-05-2008, 12:11 AM | #2 |
Sort of, the general concensus is they are *loosely* based on the old Honda XL series. But as I understand it, they are pretty much unique to China, and parts do not interchange with the Hondas, with a few notable exceptions.
There's a sticky under DS/enduro called "PARTs, PARTS, PARTS" that has some of the stuff that actually *will interchange.* Hope this helps --Vince
"Sometimes it is better to say nothing, and let people think you're an idiot, than to open your mouth and prove it." |
09-05-2008, 01:14 AM | #3 |
The bottom end is real close to a xl185 by my comparisons.
The other thought is they are based off the cb125 engine. Allen
09-05-2008, 01:44 AM | #4 |
I heard the stroke and timing is completly different among other things.
<div><a href="http://www.youtube.com/watch?v=X2ilH...s</a></div><br /> |
09-15-2008, 02:41 PM | #5 |
Thanks for the help!
Im looking more for sprockets(drive)So far I got 3 I got on line. Annnnnnnnd they dont fit :evil: I know shaft hole is 20mmx17mm but the teeth are a weeeeee bit off. |
09-15-2008, 03:45 PM | #6 |
You should be able to find the part numbers under "Sprockets, 428, 520" in the D/s forum, sprocket numbers and what not. As well, the guy with the knowledge of all things sprocket, would be Bruce from EJ cycles...
Here's the link: http://www.chinariders.net/modules.p...ewtopic&t=1393 --hope this helps --Vince
09-15-2008, 03:48 PM | #7 |
There's also a compatability chart under tech info, It's for the gy- and clones.
I have all of soberday to satur up!! |
09-16-2008, 12:44 PM | #8 |
Yes. Call Bruce at 330-274-0098. He will have the answer and probably the correct part.
You NEED to call him to get ahold of him. Allen
