05-15-2022, 11:16 PM | #46 | |
And what to start with (another key?, from what?). That is, in case its recommended. I can hold my own with tools and own quite a bit of them, but don't have special equipment. TORKER. |
05-21-2022, 05:34 PM | #47 |
Does the CRF/XR 100 keys fit our engines?
TORKER. |
07-22-2022, 08:26 PM | #48 |
news about flywheel keys?! i wrote joe and he told that he s out of stock and he would not ship me anyway (oversea shipping)…
anyone with ideas or other factory ?? |
10-19-2022, 10:41 AM | #49 |
make your own with a piece of steel, a file and lot of patience?
10-19-2022, 10:47 AM | #50 |
I have two. I could part with one of them. PM me.
02-21-2023, 10:36 AM | #51 |
Any install video and purchase link for this? Thank you
Yesterday, 10:20 AM | #52 |
Why not just dremel part of the old key, fairly certain that's all the resellers are doing.
Yesterday, 10:58 AM | #53 |
You would have too much play. The 4 degree timing key is machined with an offset.
Yesterday, 01:09 PM | #54 | |
A timing advance key has a lower section that fits the slot in the drive shaft, and an offset half round upper half that fits in the rotor. Neither side is "ground down". You can see in the photo, the upper and lower parts are the SAME width. It is just offset. The offset key must fit tightly on the shaft and in the rotor, so you can't just grind off metal to make the offset.
No matter where you go, there you are Last edited by Thumper; Yesterday at 03:35 PM. |
