11-13-2024, 10:58 PM | #32 |
I thought tariffs are paid by the importer of record, at customs, not the manufacturer in the country of origin. The importer might be ordering parts, like a domestic auto manufacturer buying relays or windshield wiper motors, or could be a big box store getting finished clothes washers or dryers ready to sell. Cell phones, toasters, microwave ovens, whatnot, the importer pays the tariffs and the increase is usually just passed to the consumer. I think the idea is that the higher prices encourage the consumer to choose the product made in the USA.
That is, the manufacturer of origin probably suffers lower sales since their stuff costs more, but they don't pay the tariff. Big box store just charges more for the BBQ grill, wheel barrow or whatever. You can check me on this, but I think this is how it works. I don't think you can collect taxes directly from a manufacturer like Kia or Fiat. Maybe the importer can ask the manufacturer to pay all or part of the tax. Not sure if that ever happens. I guess it would have to be a contractual arrangement with the buyer, and might make the contract too expensive for production. Regarding individual sales like buying a bike directly from the manufacturer thru the internet, I think the individual might have to pay for the shipping AND the import tax. If you buy from a domestic distributor like MaxPro, they would pay the import tax, likely increase the price of the bike to compensate. The import taxes on Japanese motorcycles in the mid-80's were circumvented by new models under 750cc. Remember that? You could buy a Suzuki 4 cylinder 700ES!
No matter where you go, there you are Last edited by Thumper; 11-16-2024 at 02:29 PM. |
11-14-2024, 02:46 AM | #33 |
I honestly don't know. I just saw him on Rogan talking about how he loves the word tariff. Then I noticed shipping times increase, but that could be due to the fact that I live in Podunk, WY. When it comes to business, I can't tell the difference between a business man and a confidence man.
2023 Hawk 250 from XPRO off of Amazon MOUNTAIN MAN RC + MOTO on YouTube "If there were more bloody noses, there would be less wars." - Hagbard Celine John 2:15 So He made a whip out of cords and drove all from the temple area, both sheep and cattle; He scattered the coins of the money changers and overturned their tables. |
11-14-2024, 07:32 PM | #34 |
I do not know for certain if my fuel pump is failing. I can hear it before I start the bike, but not when it is running. The crapping out and failure to idle could be the fuel pump.
I posted this earlier in this thread https://www.chinariders.net/showpost...9&postcount=22 Here it is still mounted to the tank: It wouldn't make sense to try and run it while it is dry (maybe not even good for it), so I will wait until I get it all back together and try powering it with a 12V source (ignition off) if it keeps stalling and refusing to idle. Replacing the pump can be done without even removing the tank, and I wanted to inspect it while I was checking the valves and replacing the spark plug. I found no kinks in the fuel line, no reason for the problem. I hope it is just the fuel pump. It would be an easy fix and a replacment is on the way, hopefully within a few weeks I can't find any fuel pumps that look anything like this online. MaxPro has ordered a replacement. I guess I am getting a crash course in EFI troubleshooting.
No matter where you go, there you are |
11-14-2024, 08:29 PM | #35 |
One other thing... I did remove the restriction tip and left it off becasue it sounds so much better. I will put that back on for the testing after reassembly. I doubt it is enough to make a difference, and I will replace it with a Fisch moto spark arrestor at some point.
When it starts to stall and fails again I will move onto TPS, injector, temp sensor. This is a fairly simple injection system. Maybe the map needs a reflash.
11-14-2024, 10:36 PM | #36 |
Thumper, that's about what I expected to see with it out of the tank.
There's 2 plastic tabs on each side of the main housing that you could pry on and the upper piece of plastic will come off to expose the metal pump housing. Fella could probably find some markings on that metal housing or pull some measurements and find a replacement that could be dropped into the housing. Would require a bit of soldering to reconnect the wires but the actual pump is definitely going to be an off the shelf part
11-15-2024, 08:08 AM | #37 |
I was thinking that it could be just a partially blocked injector. The symptoms make sense and this happened within 40 miles of first start. There's no filter after the pump. I can add one.
I wish I had a new injector to swap out
11-15-2024, 10:41 AM | #38 | |
11-15-2024, 11:11 AM | #39 | |
It was very easy to remove the injector. The fuel supply has exactly the same pinch connect as it has at the tank, and the 12V connector is held in place with a bale that is easily pried off. A single 4mm allen bolt secures it to the throttle body. A long allen wrench gets to the 4mm bolt through the frame. One with a universal round end is best. I do have carb cleaner and I can power the gate with 12V to at least let it drain, but I won't get that kind of stream!! I sure wish I had a spare new injector for a quick test. Part # is MEV7-053. It makes a nice solid click when powered, so I am sure the gate is working. All I can find so far is other MEV7 injectors with different ports/connectors. Please let us know if you find a MEV7-053 4 hole injector.
No matter where you go, there you are Last edited by Thumper; 11-15-2024 at 12:26 PM. |
11-15-2024, 12:14 PM | #40 |
I see what you mean! Those are tiny! I'm running into the same issue in searching. All of the ones I'm finding are 1-3 holes instead of 4 : /
11-15-2024, 06:09 PM | #41 |
Down here where I live the performance/speed shops will clean and flow test injectors for around $12.00 each.
Could be worth finding a local shop up in the KC area and have them throw it on the bench? https://www.tmsauto.com/fuel-injection-service/ I've cleaned and flow tested injectors myself at home with some simple Arduino code and a spare high pressure pump. But it was pretty sketchy and messy without the right equipment
11-15-2024, 07:52 PM | #42 |
I was able to do a back flow carb cleaner rinse with the injector activated (open) with aligator clamps powering from the bike's battery. It went well. The on/off click is distinct and flow clearly opens up.
I did hear the fuel pump when I turned on the key, and it cycled out as it produced pressure. Seemed normal. Also, when cold, it started easily and ran OK briefly before it began to stall and misbehave. There is a TPS and what appears to be a second sensor on the throttle body that is likely sensing some aspect of air flow (pressure?). And then there is the control module itself. I think the temperature sensor is on the cylinder, appears to be exposed to coolant. One of these things is not operating properly. I have a new fuel pump on the way, but that will take some time. The fact that the torch spark plug was sooty tells me it might be too much fuel at idle, not air. And it blew some barely visible smoke when I was able to restart it after stalling (needed ~1/4 throttle or more). It was burning excess fuel! I did replace that plug with a new NGK plug. I am leaning towards a sensor or the control module as culprit now. The pump whines as it should, and the injector is opening and closing. MAYBE I cleared it up with the injector flush, but I am a bit skeptical that was even needed. I need a tube of gasoline resistant RTV to mount the pump back on the tank and at that point I will test it.
Yesterday, 09:34 AM | #43 |
I took the gas cap off this morning to clean out all of the green crap that would leak everywhere when opening the tank and found that the cap could not physically vent air which is probably why the fuel pump died. There are two holes on the bottom that were never drilled out after being molded and assembled. I am still waiting on the replacement.
Yesterday, 10:55 AM | #44 |
I filled the tank to check mpg on the next fill. I don't have anymore green stuff from the tank cap. Whatever it was, it is gone. It seemed like oil.
I assumed that my fuel pump was the problem when it began misfiring and stalling at ~40 miles. But since the spark plug was sooty, and then I found the oxygen sooty as well, it was obviously running way too rich. It was clearly the injector sticking open since it runs perfectly after I cleaned it up while repetitively activating the gate (12V battery), it must have freed the thing up. This is the ONLY real problem I have had with the Paladin, and it was easy to fix. I've owned 4 crate bikes: Bashan Storm, which had a few assembly problems but ran great TBR7, which must have been a COVID assembly line mess-it was terrible 5 speed Templar X, first gen 6 speed Templar X, second gen My son still has his 6 speed Templar X Now the Paladin. I worked on a KPX, and rode it. I found it to be a nice ride, similar to a Honda. It felt similar to the Templar X, made about the same 20hp. The Paladin is much more impressive than any of them. The rear suspension and swingarm are beefier and better engineered. The wiring harness on the Paladin is more refined, with more attention to detail like the shrouding and retention under the rear wheel well. The headlight assembly fits better than any that I have seen so far, and the original headlight is better as well. The cooling system is excellent, well built, fits well. All stainless steel and great components. Now that I have worked through the kinks, this is absolutely the best crate bike I have ever ridden or worked on. I am going to put a Fisch moto spark arrestor on it, and a much bigger rear tire. I am thinking at least a 140 width. There is more space there, and it will easily take a 150. This bike makes so much tractable power, it will easily power wheelie in the dirt with a decent tire back there! It already climbs like a goat!
No matter where you go, there you are Last edited by Thumper; Yesterday at 08:48 PM. |
Today, 12:45 AM | #45 | |
Sucks so bad you are still waiting. Hopefully they ordered a surplus to keep in stock. |
