Old 11-14-2024, 09:58 PM   #31
Picollo   Picollo is offline
Picollo's Avatar
I found the 32-trottle body on eBay. Can you give me a link where I can get the fuel injector and which exhaust upgrade you use? Thanks.
Never mind, I found it and already ordered it.
I didn't buy a new exhaust. I am unsure if that would be contra-productive since no O2 sensor is on it.
I checking for updates here since it seams you know what you doing.
Kawasaki Vulcan 1700 Classic
Kawasaki Vulcan 650S
Honda Rebell 1100
Vitacci Tank 200 EFI
Old Today, 02:55 AM   #32
danklyrides   danklyrides is online now
This is the exhaust I got. It has the bung for the O2 sensor built in.
I'm glad you found the injector! The place I bought mine from didn't have any more.
Cheers!
Dankly
Old Today, 03:31 AM   #33
I searched for a high-flow alternative for the stock paper air filter but I wasn't able to find one that fits in the Tank air box. So back to AliExpress!!
Intake kit
Coupling
Filter
I had to compress the aluminum intake tube about 5mm to fit nicely under the engine pivot cross bar (red arrow in picture). I just squeezed it in my bench vise.
I wanted to keep the evap system and crankcase vent functioning so I drilled a hole in the tube and used a tire valve stem as a fitting (green arrow in picture). I like the way it came out.
I took it for a 30 mile ride and it is running great! I'm very pleased with it and think I am done with performance related modifications. Just to be clear, I didn't NEED to do any of this but I really enjoy tinkering and it is really affordable on a GY6.
The last pic is my temporary solution for the transmission vent tube. The little stick on holder that will keep it up and out of the way for now
I think the next thing I will look at modifying is the suspension. The rear shocks could definitely be better
Cheers!
Dankly
ID:	32272   Click image for larger version
ID:	32273   Click image for larger version
ID:	32274   Click image for larger version
ID:	32275   Click image for larger version
200 efi, tank, vitacci
