Go Back   ChinaRiders Forums > Technical/Performance > Adventure Bikes
Old Yesterday, 04:06 PM   #1
stoppre12211   stoppre12211 is offline
223cc/zs165mm big bore kit above 67.7mm
hey guys.
Not sure if this is a bad solution, but I was really hoping to bore out my 223cc/zs165mm on my Vitacci Titan EFI. The only bore kit that fits the 15mm wrist pin available will go from a 65mm piston to a 67mm piston. I dont find that gain worth the effort. But I was wondering, could I use 15mmIDx16mm or 17mm to fit the larger wrist pin requirements of other cg250 big bore kit. Just raise the wrist pin OD to fit the 17mm 72mm-75mm bore kits. Let me know what you think.
I know its going to have ramifications to compression ratio and EFI flash but would this wrist pin sleeve solution even be viable. thanks.
existing 67mm bore kit
https://gstreetperformance.com/produ...dirt-bike-quad
desired bore
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
example bushing/sleeve to go from 15mm wrist pin to 16mm or 17mm or 18mm
https://www.fixsupply.com/706019-iso...-mm-dia-flange
Old Today, 10:03 AM   #2
XLsior   XLsior is offline
XLsior's Avatar
Dont bother
Also why have asked the same question on 4 or more different forum sections...
If your cylinder says 200cc on the side none of these kits will work.
