Old Yesterday, 03:49 PM   #1
stoppre12211   stoppre12211 is offline
Big bore kit for 223cc/zs165mm
hey guys.
Not sure if this is a bad solution, but I was really hoping to bore out my 223cc/zs165mm on my Vitacci Titan EFI. The only bore kit that fits the 15mm wrist pin available will go from a 65mm piston to a 67mm piston. I dont find that gain worth the effort. But I was wondering, could I use 15mmIDx16mm or 17mm to fit the larger wrist pin requirements of other cg250 big bore kit. Just raise the wrist pin OD to fit the 17mm 72mm-75mm bore kits. Let me know what you think.
I know its going to have ramifications to compression ratio and EFI flash but would this wrist pin sleeve solution even be viable. thanks.
existing max big bore kit https://gstreetperformance.com/cdn/s...8155&width=990
bore kit that would require sleeve to raise from 15mm wrist pin to 16mm wrist pin.
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
Old Yesterday, 04:56 PM   #2
dirtbkr188's Avatar
You intend to use the stock 15mm wrist pin from your engine and insert sleeves to use a piston that takes a bigger diameter wrist pin? Not sure I'd want anything to do with that, but that's just my 2ยข...
