Old 11-05-2024, 01:03 PM   #16
onthefly   onthefly is offline
Well crap. Hopefully it's not too long of a wait. I was going to do a Google image search to see about sourcing something in the states, but I gotcha. Let's hope they start stocking these parts stateside
Old 11-05-2024, 07:40 PM   #17
Mumen Rider   Mumen Rider is offline
Mumen Rider's Avatar
Old 11-05-2024, 08:11 PM   #18
GypsyR   GypsyR is offline
GypsyR's Avatar
Is that a "returnless" PWM type pump?
2023 Templar 250 X
Old 11-05-2024, 09:24 PM   #19
No, I don't think it is based upon only being a two wire setup and there is no fuel pressure sensor.
Old 11-06-2024, 12:04 PM   #20
This looks close. It seems to resemble the hawk 250 fuel pump, everything stateside is priced around $120. That being said, if you confirm the pump once you have it removed, I may buy one from Aliexpress just to have on hand.
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
Old 11-06-2024, 02:58 PM   #21
I thought the pressure sensor is built into the pump, but there's no feedback line (only the two wires for power and ground). There must be a sensor at the throttle body. How would it know when to turn on the fuel pump, or how long to run?
No matter where you go, there you are
Old 11-10-2024, 02:03 PM   #22
misfiring and stalling
I have contacted Zora/Maxpro llc and included the video of the bike misfiring and stalling. I did the engine code test (hold throttle, turn on, drop throttle after the engine light turns on) and I got no flashing code. It doesn't seem to have stored a fault code. That was a cold start. It seems to run OK for a few seconds, then the symptoms begin. Then it happens every time you try to start it, and I had to twist the throttle some (maybe 1/4 throttle or less) to get it to start at all after it ran for 30 seconds or so.
Old 11-10-2024, 05:08 PM   #23
Looks like you'll be replacing your fuel pump too after watching that. You can plug in an OBD-2 reader under the seat to see if there are any stored codes. Mine had a stored code for low battery voltage which was probably the battery being disconnected while running at the factory.
Old Yesterday, 06:12 AM   #24
It sounds like changing the fuel pump will be easier than changing a spark plug! I might do both since I will have the tank off.
Old Yesterday, 09:11 AM   #25
Between fit/finish and fuel pump issues, i'm wondering if these are redesigned for the US market and truly first run of the model. I recall mention that the Paladin has been sold previously in other countries, and if that were the case i'd think these issues would have surfaced and been addressed by now. Hopefully Xpro/Zumaav can remedy the next batch and we start hearing of less issues and more positive ride reports.
Old Yesterday, 09:25 AM   #26
They're sold in other markets with different engines and they are mostly carbureted. The CBS300/NB300 are the most common engine used in the S8 models followed by the ZS172/175 air-cooled engines, the NC250/300/450 seems to be phasing out slowly. The Loncin engines are "rare" in Ukraine and in Russia they're not "officially" released.
