Old 10-25-2021, 01:25 PM   #1
Goodwood   Goodwood is offline
Anyone gotta link for a PAIR block off plate???
Any links, please. Pod air filter and aftermarket exhaust was gonna ditch it.
Old 10-25-2021, 01:51 PM   #2
Ursa_Adv   Ursa_Adv is offline
Ursa_Adv's Avatar
What kind of bike do you have? If it's the standard 250 (223cc) engine that most of the Chinese dual sports come with, you should be able to use these:
https://gy6racing.com/universal-egr-...-gy6-scooters/
I used that one on my Orion RXB. Bolted right up. No fuss whatsoever.
NC250 Swapped '20 Orion RXB250L
Build Thread
Old 10-25-2021, 02:33 PM   #3
You can make one with a piece of 1/8" think aluminum or steel flat bar. Aluminum will be the easiest material to work with. I've made all of mine out of aluminum. Use the stock gasket as a template.
Old 10-27-2021, 12:19 PM   #4
FlyingBasset   FlyingBasset is offline
Jerry saving the day as always!
While we're on this topic - does anyone know what this third tube going from the bypass module is doing? It looks like it goes to the tank but I can't be sure.
https://imgur.com/a/lSvFuUK
I know left goes to airbox and bottom is from the head - but before I cut this third one short and cap it I wanted to see if anyone has a better solution.
Edit: Image isn't displaying so I linked it as well.
Old 10-27-2021, 12:54 PM   #5
mototech77   mototech77 is offline
mototech77's Avatar
I did this bypass the same way JerryHawk250 did on my last bike, but it was 9 years ago. If memory serves me correctly, the larger tube goes to the air box and can be capped there. The smaller tube was a vacuum line controlled by either a solenoid or reference vacuum tap off the carburetor, and can also be capped at the source. Either way you should be able to just trace the lines back. If I am off here, someone please correct me.
2021 Lifan Xpect EFI
2012 DF250rtc
1982 Yamaha Virago XV750
1982 Honda Twinstar CM200
Old 10-27-2021, 01:15 PM   #6
Yeah after digging into it more the smaller line goes to the elbow flange between the carb and engine. I was a bit confused because in some older posts I saw people saying it goes to the crankcase.
There is another separate set of tubes that do seem to link the crankcase, airbox, and a small filter/valve - so probably just a breather tube - but it looks like I'm good to leave those!
Old 10-27-2021, 03:59 PM   #7
tknj99   tknj99 is online now
This would be a good side hustle for someone.. with my old Honda Fury there was a guy who fabricated and sold block-off plates (2 were required) for $15 if memory serves, although it was slightly more complex than what we require here.
Old 10-27-2021, 04:21 PM   #8
These are so simple to make. Personally I wouldn't pay anyone for them. Pick up a piece of 1/8" aluminum flat bar at Lowes or Home Depot for less than $5. Use the gasket and trace it out. A hacksaw or metal cutting blade on a jigsaw makes quick work of it. Drill two holes and file or sand the edges. Less than a 5 minute job. You can make quiet a few from a 3' long bar.
Old 10-27-2021, 04:38 PM   #9
I theaded the hole and used a stainless hex head bolt.
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
Old 10-27-2021, 05:00 PM   #10
I've thought about doing the same but had a piece of aluminum stock handy already.
Old 10-29-2021, 01:47 PM   #11
Joe Schutts   Joe Schutts is offline
ERG Block Off Plate...
Hi,
Here's a link for a ERG Block Off Plate on EBay. It sells for $5.85 with $4.95 shipping costs (go figure)...
Hope this helps...
Joe...
Old 11-02-2024, 06:49 PM   #12
Alicc04   Alicc04 is offline
Gasket for the plate
Hey guys, I started doing this on my venom ghost 250, but it’s been 1300 miles since I got it. So now the gasket that comes with it, is baked on and I’m not sure how to take it off with braking it. Any chance anyone know where I can get a gasket?
