Old 04-01-2023, 10:09 PM   #16
buzz   buzz is offline
enjoy glad it all worked out
Old 04-01-2023, 10:22 PM   #17
It's got a 120 main jet and a #40 pilot jet in there. I replaced pilot with #45, then backed off to #42. Now I think #45 might be better. I replaced the main with a #125, and also shimmed the needle ~1mm.
That stalling will go away once you get more rich fuel/air with jetting changes and needle shim. Look at the Templar resource guide for carb stuff
https://www.chinariders.net/showthread.php?t=32177
(post 4)
You will want to drill the airscrew cap next time you remove the carb. It is on the right side behind the slide height (idle) adjustment screw. And get a large knob idle adjustment screw while you are at it. All of this stuff is noted in the Templar resource.
Lots of other stuff there in the carb posts (how to get into the cxarb, etc). shmoto is still selling the jets. They fit perfect and pretty consistent jets. Price has gone up to $10 (shocking!).
Order them jets! Also, get in there and set the valve clearances ASAP.
No matter where you go, there you are
Old 04-01-2023, 10:46 PM   #18
I like the OEM YouAll Dan. It is a smoothbore and built well. You have to jet and set needle height on ANY carb. You will start over if you install the Nibbi (all carbs need jetting and adjustment!).
Either way, rejet will be needed and valve clearance needs attention ASAP. Fortunately, the valves are easy to adjust. The cable routing will work with either carb, so that's done!
Old 11-02-2024, 04:47 PM   #19
FireMedicX22   FireMedicX22 is offline
New Templar 250 not starting
Hey guys, I got my bike yesterday, other than my carb overflow constantly leaking gas, I’m not having a new issue. My bike will not attempt to turn on. I’m in neutral, brake is held in and my engine off switch is in the proper position. I took my starter cover off and it appears the gear is in the ok position and will not retract back. Any thoughts?
Old 11-02-2024, 04:55 PM   #20
Mumen Rider   Mumen Rider is offline
Mumen Rider's Avatar
If your carburetor is constantly leaking fuel you probably need to adjust the float height. Stop trying to start it, you are flooding the engine. You did not specify what gear you were referring to either, there are two behind the starter cover.
