10-30-2024, 09:28 PM | #1 |
Nothing is as easy as it looks in the video
Hey my 2024 Hawk (with carb) is at 500 miles and my chain has stretched to the point that its pretty loose. Like probably not safe loose. So here I go, watching videos on chain tightening, ordering 17 and 19mm heavy duty sockets to work the axle bolt and nut, and...that damn axle bolt did not want to come loose. It had to be sealed up with Loctite. They may as well have used cement. Ok, so after beating the socket wrench with a hammer (sorry - its the military guy in me) I get the axle nut loose and loosen the adjusting nuts on the swing arms. And I'm following the advice in the videos to set a tape measure alongside the chain and doing my best to line up the wheel with the measuring lines and keeping everything in alignment, and doing my best to pull the wheel back to tighten the chain to just the right tension and gently tighten the adjusting nuts... And every time I tighten the axle bolt, it rides back on itself and tightens the chain to some impossibly tight tension. It took a Google search and one obscure video to learn about the tension of tightening the rear wheel axle. Some videos recommended tightening the tension nuts in the swing arms first. Another video recommended tightening the axle bolt first, then adjusting the swing arm adjusters. Well, I finally got it - I found a tension I could live with that wasn't super tight. I never did find the recommended tension of an inch and 1/4, but I found a tension that wasn't crazy tight and didn't look like it would snap the chain (there's videos of chain snaps out there. They don't look like something I want to have happen). And guess what - I just completed the chain adjustment yesterday and took the bike for a gentle ride around the area to test it. And when I got back home after riding like a mile? The chain had already stretched out to: about an inch and a quarter. Go figure. I'm out. |
10-30-2024, 09:35 PM | #2 |
buy a quality chain off Amazon/Ebay, ideally o-ring or x-ring (even better) and you wont have nearly as much stretching going on
2024 Templar 250 2021 Beta 500 RRS 2018 VStrom 1000 XT Former China Bikes: Tao DBX1, Brozz 250, CSC RX4, Titan DLX, Templar X, Storm DLX 150 |
Yesterday, 06:24 AM | #3 |
You watched the wrong video.
2023 Hawk 250 from XPRO off of Amazon MOUNTAIN MAN RC + MOTO on YouTube "If there were more bloody noses, there would be less wars." - Hagbard Celine John 2:15 So He made a whip out of cords and drove all from the temple area, both sheep and cattle; He scattered the coins of the money changers and overturned their tables. |
Yesterday, 07:10 AM | #4 |
I'll find on my Templar that the tension will change depending upon the rotational position of the sprockets. It may seem loose at first but, when rotating the wheel, the tension changes in certain spots. Not sure why it does that, sprockets seem clean, no binding links in chain, sprockets don't seem out of round... Just something to keep in mind.
Yesterday, 07:50 AM | #5 | |
Yesterday, 08:35 AM | #6 |
This is why mechanics drink. And why my main rides are shafties or friction drive.
The chain being tight in one spot and loose in another is because the sprockets are not concentric. None of them are. IIRC they can be out of round by as much as .020". If both are out by that much, you are looking at .040" in one spot. Throw in a cheap or worn chain and you'll be bald like me. So, you shoot for a compromise in chain adjustment, aka, good enough. And go ride.
Yesterday, 03:30 PM | #8 |
Does the 2024 Hawk still have the box-style swingarm?
If it does, it is very easy to overtorque the axle nut and being to collapse the box section. That will throw off the tension. Besides that my solution to not having 4 hands is to jack up the bike and use something under the tire to help hold it in place, usually a 2x4 or a wheel chock if i have it higher up. Then I get the wheel roughly where I want it, get the axle barely snugged up, and use the adjusters to start to tension the chain. I am still on the stock chain at around 3k miles and it is about done, getting very stretched. Only put 2 or 300 miles on it with the stock sprocket. Edit: change 2021 to 2024 Last edited by wally; Yesterday at 03:31 PM. Reason: Edit: change 2021 to 2024 |
Yesterday, 05:39 PM | #9 | |
Yesterday, 06:42 PM | #10 | |
Current Bike: 2020 Lifan Xpect w/ JT 17 Tooth Front Sprocket Past Bikes: 2022 Honda Navi - Stolen 2016 Honda CB500x - T boned by idiot, totaled ? Honda CRF100F - 'Stolen' by grandpa ? Honda CRF70 - Sold to friends Honda/Suzuki 50cc Kids Bikes - Sold to friends |
Yesterday, 07:26 PM | #11 | |
Yesterday, 08:48 PM | #12 |
@Aussie, that could be what's happening. I ran the stock sprocks and chain for about 1500 miles and noticed the uneven tension worse then. I switched to JT sprockets and a DID o-ring and the tension change was gone when I first installed. Started noticing the tension change came back (not near as bad) after about 500 miles on the new one.
Yesterday, 09:23 PM | #13 | |
Good description
