Old 10-30-2024, 01:58 PM   #1
redhatengineer   redhatengineer is offline
Replacing shift shaft on Templar X 250
Anyone had the joy of doing this yet? Met a rock that didn't like my shifter, shift shaft, or left case cover. PSM sent me replacement parts but this will be my first time opening the case covers so I'm not sure what to expect.
Old 10-30-2024, 04:50 PM   #2
Oh crap! Bad luck. If the shifter shaft is really gone, you will be cracking open the engine to replace it. I don't think you can replace it otherwise. Good luck!
No matter where you go, there you are
Old 10-30-2024, 08:30 PM   #3
slithica   slithica is offline
I'm pretty sure you need to pull the clutch and remove the shift shaft from that side.
Here is a service manual for the cg125, your engine probably isn't a 1:1 copy but it should point you in the right direction.
https://kjaer.com/wp-content/uploads...ice-Manual.pdf
