Old 10-28-2024, 03:45 PM   #16
Mudflap   Mudflap is offline
Originally Posted by Yakpimp View Post
When I have the air filter off and look in to see the slide going up and down, it appears to be closing all the way. The cable is the same one that was on the stock carb with no changes. Do you think adjusting it at the control side would give enough slack to lengthen as needed? I hadn't considered that.
I don't need to ride it for about a week and a half so I can wait for the new jets before I mess with it again. I just wanted to understand if the jets are a logical reason for things to be running higher than expected.
Also my elevation is 146ft
Different carbs often require a different length cable. If that is the case you'll just have to try to see if there is enough adjustment. You could put the slide in without the cable attached to see if it'll idle down.
Old 10-29-2024, 12:27 PM   #17
Yakpimp   Yakpimp is offline
Good idea, I'll try that.
New jets aren't coming until Nov 2nd so I have a couple days.
carb, mikuni, mounting, rhino, vm26
