02-15-2023, 06:28 PM | #17 |
displacement
Everywhere I have looked, I hear 65mm stroke for this engine. So if the cylinder is 67mm:
Use the Spicer engine displacement calculator or equivalent to determine true displacement: https://spicerparts.com/calculators/...ent-calculator 67mm bore x 65mm stroke = 229.17
No matter where you go, there you are |
02-15-2023, 06:45 PM | #18 | |
09-29-2024, 08:08 PM | #19 | |
Reviving an old post. Has anyone installed one of these 70mm kits? What about the 72.5mm (268cc advertised as 350cc) they appear to require some clearancing of the case, obviously, as the jug is 76mm wide! |
10-22-2024, 01:32 PM | #20 |
Salut a tous, moi je suis sur un petit trail de la marque zongshen en 200cc ... équivalent a la cyclone RX1 ... j'aimerais bien augmenter la puissance mais bon ...c'est pas évident manque de pièces de rechange.... J'ai installé un refroidisseur d'huile, ...vires le carbu a dépression d'origine et j'ai installé un PWK 30 avec un filtres a Air corné.... C'est galaire a réglé c'est carbu
10-22-2024, 05:21 PM | #21 |
70mm kits are about as large as you can go into a 167fmm case. Any larger and you would have to open the case hole, At which point the return on investment evaporates unless you have the tooling/equipment to do it yourself.
However I'm not even sure it can be done without impacting headstuds and oil galleys. So IMO anything over a 70mm bigbore kit would be better spent on an entirely new better in class engine. |
