10-13-2024, 12:31 AM | #1 |
Paladin 300
Who knows about this new(?) bike? Looks like a Templar 250 X with a 300cc fuel injected, 4 valve head, water cooled, 6 speed, counter ballanced.
https://www.powersportsmax.com/produ...ducts_id/26793 |
10-13-2024, 01:36 AM | #2 |
Looks pretty sweet. 25kw is 33.5hp. Not too shabby.
10-13-2024, 03:12 AM | #3 |
That is the sweet spot. Just wish it was air cooled.
10-13-2024, 09:07 AM | #4 |
No reviews,don't think any were sold.
10-13-2024, 09:45 AM | #5 |
I saw this bike on the power sports website for the first time yesterday. It seems to be a fairly recent addition to their line up. Is there any history with this engine?
10-13-2024, 10:20 AM | #6 |
Waitwaitwait a second. Wasn't Paladin the name of a show from WAY back? Black and white. Have gun will travel?
NO! PALADIN WAS DUDE'S NAME!! LOLOLOL
10-13-2024, 11:06 AM | #7 |
Hmm? This is enough to overlook my fear of EFI. 6 speed counterbalanced 4 valve engine, and liquid cooling (which is awesome for off road slow trail riding, just add a fan).
I found a Loncin engine that seems to match. Loncin KE300F If this is the same engine, that bore x stroke is oversquare which will allow higher rpm. Their plot of power versus rpm goes to nearly 10k rpm! Shorter stroke also means a shorter cylinder, more room up top for valve access. Nice. At 78mm x 61.2mm, it has 292.4 cc displacement calculated on the Spicer displacement calculator (if this is indeed the same engine). It does look like the same engine. This is a promising development.
-NOS 2020 KTM 250SX (2-stroke motocross) Last edited by Thumper; Today at 11:48 AM. |
10-13-2024, 12:47 PM | #8 |
It's a Kawasaki KLX300 engine clone, same bore and stroke.
This engine is NOT EPA certified to the best of my knowledge so it'll end up being an Orion 250 Loncin situation where if you do get it registered they will end up revoking it eventually. |
10-13-2024, 02:11 PM | #9 |
The Power Sports website lists this bike as EPA certified but not CARB certified.
My Templar 250X came EPA certified...as an off road only mc. With a MSO stating "motorcycle" I easily obtained an Oregon license plate and title. |
10-13-2024, 02:21 PM | #10 |
Your Templar X 250 also has an engine stamped with the wrong code to avoid EPA certification for a newer engine model. The boxes all state off-road only and you had to specifically ask for an MSO saying "motorcycle" because the default is "off-road motorcycle".
10-13-2024, 02:34 PM | #11 |
I’ll bet that getting a tag for road use here in FL would be difficult. And I bet that seat height would be difficult too…
10-14-2024, 11:33 AM | #12 |
Wow, it appears to actually have a kill switch. The Chinese are getting very sophisticated these days.
This appears to lack some street legal equipment for my state including a chain guard, full rear fender, reflectors, and the turn signals are too small to even meet DOT requirements. All this is the same as my Orion was. In fact, the signals and dash cluster appear identical, and possibly also the mirrors. Still, I think with some basic modifications and bullying the seller into putting "motorcycle" on the MCO I might be able to get it rammed through here. Very interesting. If this actually makes 33 horsepower I will eat my hat. A real KLX300 only makes like 24, tops. But if it does, I'll also buy one right now. |
10-14-2024, 11:45 AM | #13 |
The power curve is there, just scroll down in the embedded window (link below). They are definitely claiming peak of 25kW. I see the curve is a linear build. It looks like about 26 hp at 7000 rpm (20kW).
Loncin KE300F
Today, 09:31 AM | #14 |
Has anyone made a purchase on one? I am new to this forum and have never ridden a dirt bike. I was planning on purchasing a Templar X but for not much more $ the Paladin is very enticing. Looking at the specs it is listed as weighing the exact same as the Templar X which is odd.
Today, 11:40 AM | #15 |
I am going to miss this first traunch of Pallidin 300s. I think they'll sell out within a week or two, but they'll get more.
I would buy one. It is a Zuumav, and I am familiar with their qualty and have seen the very minor component issues that were easy to fix or replace. Templar owners here have had good overall experiences with them. I've had two of them, and my son still has his X. The only issue we had with his X was the tailpipe section was not properly bent from the factory, but PSM replaced it for free. Otherwise, the bike has been just plain flawless. We haven't even had to replace the chain yet. Most of these bikes will probably need a chain within a thousand miles. The EFI might need modification to enrich the base curve. It will probably run lean OEM. Not sure. I do not want to run too lean. It might even be possible to just replace the EFI unit with a flashable/adjustable one. Entry price there is about $200, but better units like the DynoJet power commander costs ~$350. The resitor on the Intake Air Sensor approach lays a fixed increase all across the operating range which isn't perfect, but probably worth a try. There is a whole lot of info on this all over the various dirt bike forums now. I guess I am over my paranoia about EFI. I just need to be educated and learn to test/adjust it so I can recognize any problems. I sold my Temp X in anticipation of probably getting a TM38, but this Palladin looks more like what I want. I have the dual sport converted KTM 250 for now. I want to wait until after Jan 1 so I can avoid 2024 personal property tax on the new bike. It's only $100, but I don't mind waiting. Maybe they will have a New Years sale. Oh, and I noticed in the photos that the linkage has the same extension on the lower legs of the KKE shock, so it will be a breeze lowering it 1 to 3 inches. And I have a spare KKE shock to toy with, if it fits. There is a good 1" or more available on the front fork clamp region to allow dropping the front end as well.
