Old 10-10-2024, 04:45 PM   #1
Patch56   Patch56 is offline
Hawk 250 tire size
Hello all,
What is the best tires for a hawk 250 that is mostly ridden on streets? Also I am having a hard time finding the 80/100 21 front and 110/100 18 rear tires. Where are you guys purchasing them from? Also would you change out the bearings while I am at it?
Old 10-11-2024, 07:09 AM   #2
buzz   buzz is online now
Amazom or ebay, if bearings spin easy bearing are good.
Old 10-11-2024, 08:03 PM   #3
In standard sizes a 3.0x21 front and 4.6x18 rear are as close as you can get. 2.75x21 and 4.10x18 will also work, but are a tad smaller in width and height.
You can also run 90/90-21 up front and a 120/80-19 or even better a 120/90-18 rear (closest in diameter to stock).
As for the bearings, you could at least check them. If they are bad you can order new ones and do them another time. Removing the wheels isn't that hard of a job, especially the front.
Old 10-11-2024, 08:47 PM   #4
sburk   sburk is offline
Did you mean 120/80-18 and 120/90-18?
Just wondering because I am also looking to get diffent tires.
Old Today, 05:20 PM   #5
wally   wally is offline
I use these tires as "Street" tires on my hawk. They worked without messing up the speedometer too much:
Shinko 270 Super Classic TiresSKU: 1297213
Wheel Location: Front
Tire Size: 3.00x21 57S TT
Shinko 270 Super Classic TiresSKU: 1779926
Wheel Location: Front/Rear
Tire Size: 4.50-18 70H TT
I got them from Cycle Gear as there was one close enough and they included install. They worked fine altho if i remember Cycle Gear balanced them very poorly and I had to re-do it. Get nice heavy duty tubes too! I like: Michelin Ultra Heavy Duty MX Tubes
bearings, road tires, tires
