Old 09-12-2024, 03:45 AM   #16
danklyrides   danklyrides is offline
Update at 850 miles
I've been on some long trips on my other bikes so haven't ridden the Tank a ton recently. I've tracked fuel mileage for 7 fill-ups so far and my average is 68.4 mpg, best so far is 72.1 mpg.
I installed some small LED visibility lights on the front fork shields. Here are some of the install pics.
I will post some pics of the final result later
Cheers!
Dankly
ID:	31934   Click image for larger version
ID:	31935   Click image for larger version
ID:	31936   Click image for larger version
ID:	31937   Click image for larger version
Old 09-24-2024, 05:02 PM   #17
AndoSama   AndoSama is offline
Hello, I am also a new owner of a tank. Can you tell me what you're getting for max speed? I feel as though mine is a bit underpowered compared to the old falcon 200 it is replacing (they have same engine, just tank has efi)
Old 09-24-2024, 09:57 PM   #18
On a flat road with the boxes mounted but no cargo I can get 53 mph. 54 if I go into a bit of a tuck to cut wind resistance.
I'm also not very pleased with that. I've been hoping that things would loosen up a bit and it would get a little faster with miles...but I just hit 1000 miles today, and no luck.
Old 09-25-2024, 12:12 AM   #19
Here are the pics I promised of my front fork lights installed and working. Next, I really need to do something about the front turn signals. They are really bad!
ID:	32010   Click image for larger version
Old 10-02-2024, 10:11 PM   #20
I fixed my wimpy turn signal issue. Got this set from Amazon:
LED Turn Signals
I mounted the fronts in the stock location using reflector brackets that I took off of my KLX 300. To keep the wiring clean I soldered the original connectors onto the new lights.
For the rears, I again used the original mounting spots but I used butt connectors with built in heat shrink because all the wires hide behind the license plate light.
I now have white running lights (instead of red) in the front and still have red ones in the rear. Both front and back have sequential amber lights when in turn signal mode. All of the lights are much brighter than the stock ones.
ID:	32037   Click image for larger version
ID:	32038   Click image for larger version
ID:	32039   Click image for larger version
ID:	32040   Click image for larger version
Old 10-13-2024, 02:35 AM   #21
I took my Tank offroad a few weeks ago. What started as smooth and wide gravel roads quickly declined to steep down hills, rock gardens, baby heads and deep ruts. I DEFINITELY shouldn't have been there on a scooter...but it was a lot of fun! If I had to go back up the hills, it would have been an issue but down was cool and I took pavement home.
The only issue was that the aft exhaust mounting bracket broke. The muffler is a big, heavy, ugly steel thing and the metal got fatigued and broke from all the bouncing. A couple of pictures are attached below.
I had a couple of options to fix this: take the muffler to somebody to weld the bracket back on...or get a new exhaust. I definitely liked the second option better!
I got on AliExpress and found this kit. It was on sale at the time so my total cost was $87 including shipping. It is way better in almost every way.
Much lighter weight
Sounds a lot better
Looks great
And...it actually made the scoot faster!! I got up to 58 mph the other day. Previously my high speed was 55. YMMV, but I was pleased with this.
I blame myself for the muffler breaking. I am at about 1,200 miles now and still really like the Tank. As an added bonus, my last fuel economy (before the new exhaust) was 73.4 mpg.
Cheers!
Dankly
ID:	32103   Click image for larger version
ID:	32104   Click image for larger version
ID:	32105   Click image for larger version
ID:	32106   Click image for larger version
Old 10-13-2024, 06:31 AM   #22
Mudflap   Mudflap is offline
Looks good. Strange that they have a picture of a scooter with the stock exhaust rather than the one they're selling.
About 6000 miles on my Clash and it is indeed a little faster now compared to new. Adding a windshield helped top speed and MPG.
Old 10-15-2024, 10:21 PM   #23
I put a small generic windscreen from Amazon on the Tank. Link here
I initially had it secured with the 4 screws from the tiny stock shield (green washers in the pictures) and 2 small brackets that went to the back of the instrument cluster. This worked ok to hold it but it would bounce around and flex so I was worried about metal fatigue in the instrument mount. I added two extra supports that anchor to the handlebar and now it is nice and solid...but pretty ugly
Between that and my new muffler and the engine loosening up (1200 miles so far) I was able to get up to 60 mph GPS on flat ground today
I have finally achieved the advertised speed!
Cheers
Dankly
ID:	32120   Click image for larger version
ID:	32121   Click image for larger version
ID:	32122   Click image for larger version
ID:	32123   Click image for larger version
Old 10-16-2024, 08:23 AM   #24
Same windshield I had but a much better mount. Mine cracked at the upper holes from rough roads at high speed so I replaced it with a bigger thicker windshield. The Tank has more mounting options than the Clash with it's plastic covered handlebar.
Old 10-19-2024, 02:45 PM   #25
GOLDFIELDGUSS   GOLDFIELDGUSS is offline
Head Scratching Red front running lights
Hello, I am new to this forum. I just purchased a Vitacci Tank 200 Deluxe and it has red running lights to the fron as part of the turn signals. They are illegal were I live so i need to disconect the wire that lights the red LED and leave the anber wire light intact. There is a brown wire a green wire and a orange wire going to the left light and a brown wire a green wire and a blue wire going to the left right light. Can I cut one of these wiers to shut off the red running lights? If so what one? Thanks in advance for any help.
Old 10-19-2024, 04:26 PM   #26
Traditional colors for turn signal wires are light blue and orange with green for a ground. Brown is probably running lights. No guarantee that scooter follows the norms.
Old 10-20-2024, 10:49 PM   #27
@Mudflap is exactly right. Cut and cap off the brown wires and that will take care of the red running lights. If you ever decide to replace your turn signals to get the front running lights working again in a proper color (white) then see my Post #20 above. Good luck!
Dankly
Old 10-29-2024, 09:20 PM   #28
Since I put the aftermarket exhaust on my Tank I've been worried that I'm running too lean. I don't have any data to support this, it just feels that way...kind of like a little 2-stroke that is getting close to a soft seize...it's hard to describe. Anyway, in an attempt to fatten the a/f mixture I got a new fuel injector from PMC Racing. It is a direct swap and they say it flows 20% more fuel. I've only ridden 5 miles with it so far but it seems "happier". Also feels a little peppier in the mid-range, but it's hard to say. I'll keep an eye on fuel economy and see how that changes. Pics attached.
As an aside, the screw that holds the injector in place was barely still there. It had loosened almost all the way and I'm sure it would have fallen out all together soon. When I installed the new injector, I put some blue Loc-Tite on the screw. I'll add this to the list of things to check whenever I have the seat bucket out.
Cheers!
Dankly
ID:	32205   Click image for larger version
ID:	32206   Click image for larger version
Old 11-07-2024, 12:39 AM   #29
I can't leave well enough alone, so I got the PMC Racing 32mm throttle body for the Tank. It's supposed to work well with the bigger injector. I haven't ridden it yet but it looks cool. I'll report back with my thoughts.
ID:	32226   Click image for larger version
Old 11-10-2024, 10:22 PM   #30
I put 40 miles on the Tank with the new throttle body installed. No issues at all with the install. It bolts right up and all the sensors that I swapped from the stock unit fit perfectly. It starts and idles just like it should.
All info below is just my subjective feeling. I have no data to back it up. YMMV
I think that this is a really good mod! The scoot seems to accelerate much more quickly and the extra "power" means that it takes less throttle to hold a given speed. Since the engine isn't working as hard everything feels smoother. I don't know how fuel economy is effected yet but I'll let y'all know.
I think the combo of throttle body/fuel injector/exhaust is a good one to wake up this motor. Was it fine stock? Absolutely! But then I broke one of the mounts for the stock muffler and decided to get an aftermarket replacement instead of having someone weld the stock steel can. This freer flowing exhaust made the bike feel lean, so I got the bigger injector. PMC says that the 32mm throttle body goes well with the injector, so I put the throttle body in. Have a good one!
Cheers!
Dankly
200 efi, tank, vitacci
